Freeway/city engine break-in
Old Jul 29, 2004 | 02:39 AM
swlabhot's Avatar
Default Freeway/city engine break-in
Is it preferable to break in a built engine with city miles as opposed to the freeway miles? Is there a huge significance in the ring sealing on type of miles put in? I would have thought city break in would be appropriate. Any thoughts on this?
Old Jul 29, 2004 | 02:49 AM
boosted_dc2's Avatar
Default Re: Freeway/city engine break-in (swlabhot)
as long as there is different loads put on the motor either is fine. if your on the highway, change speeds and gears often. dont just cruise at 3000 rpm's at 60 mph for like 30 min. but i would also think that city miles would be better for break in if you can hit all the load points on the engine.
Landon
Old Jul 29, 2004 | 04:59 AM
Johnyquest's Avatar
Default Re: Freeway/city engine break-in (boosted_dc2)
pull on highway:
3rd gear, 1/4 throttle to like 1/2 way to redline, let off and coast back down to like 2k rpms...
3rd gear, 1/2 throttle to like 3/4 rpm, coast back
3/4 throttle to near redline, coast
full throttle to full redline
rinse, repeat if desired... your motor is now as broken in as it will ever be.
It's the "motoman" method and it's perfectly acceptable.
Good luck
Old Jul 29, 2004 | 05:08 AM
B18C1CYA's Avatar
you should read this i used this method and the car runs strong and uses no oil or smokes https://honda-tech.com/zerothread?id=878397
Old Jul 29, 2004 | 05:52 AM
swlabhot's Avatar
Default Re: Freeway/city engine break-in (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">pull on highway:
Good luck</TD></TR></TABLE>
This is pretty much what I planned to do but after this procedure, no running in for a further 1000 miles before beating on it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">you should read this i used this method and the car runs strong and uses no oil or smokes https://honda-tech.com/zerothread?id=878397</TD></TR></TABLE>
Yeah I've been following this thread for a while.
Old Jul 29, 2004 | 06:56 AM
swlabhot's Avatar
Break in WITH boost or without?
Old Jul 29, 2004 | 06:59 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">Break in WITH boost or without?</TD></TR></TABLE>
no boost on the breakin.
Old Jul 29, 2004 | 07:01 AM
B18C1CYA's Avatar
Default Re: Freeway/city engine break-in (DaX)
yeah no boost for the first 20 miles than ran 13psi then put like 1000miles than turned it up to 18psi
Old Aug 7, 2004 | 07:39 AM
Johnyquest's Avatar
**** it boost from day one, who cares. It doesn't matter as long as your basemap is good.
Old Aug 7, 2004 | 07:40 AM
B18C1CYA's Avatar
Default Re: Freeway/city engine break-in (Johnyquest)
you should never boost on a base map, thats all they are is a base nothing more
silverskateEF9
Apr 4, 2008 01:07 PM
supreme08
Honda Civic (2006 - 2015)
Jan 13, 2008 10:32 AM
kornerk12
Feb 16, 2007 02:27 AM
succdeez
May 28, 2003 01:56 PM
TokuiAutowerks
Jan 29, 2003 08:13 PM
