quick question: flex pipe and dumptube
Old Jul 26, 2004 | 06:28 AM
ash.zero's Avatar
Default quick question: flex pipe and dumptube
i want switch to close loop. using the flexpipe (from autozone) to connect from wastegate dumptube flange to 12" down the downpipe, is that acceptable? what's the pro/con of using a flexpipe? the shop recommended custom welding various J bends to fabricate a hard pipes, but is there any other obvious cons of using a flex pipe? thanks all.
Old Jul 26, 2004 | 07:57 AM
Bailhatch's Avatar
Default Re: quick question: flex pipe and dumptube (ash.zero)
non cons at all. you really should use some sort of slip joint or flex section because of the thermal expansion of the manifold/DP/dumptube in relation to eachother. The dump tue will stay cool until full boost then all of a sudden it will gain like 1000 degrees.
also try to make it go back in more than 12" down. something around 18-20 is good if there is room and make sure it enters at a low angle so it's a smooth transition. good luck
Old Mar 5, 2006 | 09:25 AM
Flr Power's Avatar
Default Re: quick question: flex pipe and dumptube (Bailhatch)
I know its old but has anybody found any cracking when not using a flex?
I do not think it is really needed when the welds are made right but i would like to here from someone who's had bad experiance running without a 1.5" flex.
ramboPandA
Apr 12, 2016 08:42 AM
HamiltonRex
Jan 30, 2006 06:15 PM
adictionbass
Welding / Fabrication
18
Nov 1, 2005 02:54 PM
tgrace
Aug 22, 2003 09:10 AM
importimage
Jul 13, 2003 09:56 AM
