No spark???
Old Jul 27, 2004 | 12:53 PM
birz's Avatar
Default No spark???
Ok I'll brief out my problem:
I was running the SMC+ hack and I've just switched to Uberdata. Lately I was experiencing some startup problem even when I was on the SMC+,,, 1 time out of 5 the car didn't want to start, it reved a bit and died even if I had the gaz pedal engaged to help out. Now with the Uberdata I was able to run 2 days with the car on the basemap I made, I had no cells whatsoever even in boost. 2 days ago the car just didn't want to start, all you can hear is the fuel pump when I put the key in the on position and the starter whan I put the key in the start position, no matter how long I hold the key the engine just don't start, so I went ahead and check if I was getting spark, pulled out plug number 1 grounded it to the head and asked my girlfriend to startup the car,, there was NO SPARK AT ALL and the plug was wet and smelled gaz alot due to repeatdly unsuccesful start up. So I took out the uberdata chip and put it back in my burner,, the maps were exactly the same, no corruption,, so I think it is not uberdata related,,, what could cause the ignition to go wrong?? I puted in a new cap and rotor still no luck,,, maybe the dizzy is giving up?? what else should I check for ignition related problem.
dizzy?
wires?
what else??
thanks alot
Old Jul 27, 2004 | 12:59 PM
beepy's Avatar
Default Re: No spark??? (birz)
Coil, coil wire, distributor pickup, power to coil, any OEM or aftermarket ignition modules, etc.
Old Jul 27, 2004 | 01:00 PM
birz's Avatar
Default Re: No spark??? (beepy)
so if I buy a new dizzy my problem should be solved??
btw my ignition is totally stock.
Old Jul 27, 2004 | 01:05 PM
beepy's Avatar
I would check all the wires and connectors first. Start with the least expensive repairs and go from there.
Old Jul 27, 2004 | 01:07 PM
birz's Avatar
ok I'm going to do that right away and come back with some pictures,, I hope you would still be online as youre the only one who answered me so far
Old Jul 27, 2004 | 01:12 PM
Griffin@Camtech's Avatar
Also make sure your main relay is working properly
Old Jul 27, 2004 | 02:29 PM
birz's Avatar
Default Re: No spark??? (Stickdeath)
ho w do I check that??? (main relay)
Old Jul 27, 2004 | 02:38 PM
birz's Avatar
I know the small yellow wire should be green, but I used to have an MSD BTM and I just cuted a piece of wire to put it back to stock ignition anyway here are the pics:
and while I'm at it is my dizzy an OBDII?? judging by the plug
Old Jul 27, 2004 | 03:31 PM
birz's Avatar
what the main relay has to do with spark??? I thought the main relay was for the fuel pump no??? I can't defenitly hear the fuel pump when I put key at ON but I dont see any sparks on the plugs.
so,, main relay or dizzy??
Old Jul 27, 2004 | 04:36 PM
birz's Avatar
I need some other inputs please
Old Jul 27, 2004 | 05:52 PM
birz's Avatar
please guys I beg you sniffffff
I'm so saddddddddddddd sniffff (bis)
Old Jul 27, 2004 | 06:00 PM
cstay's Avatar
u need a book to go off from that will walk you through all of the tests to go though for no spark, u need to test the ignitor (small box in the dystro) the cap rotor, all of the cylinder pos sensors, check for continuity from the wires from the dystro right to the ecu plugs and if u dont have continuity one of your wires is broken inbetween, this would be somthing i would look into concidering u just taped into wires.
Old Jul 27, 2004 | 06:25 PM
99blackcivicSi's Avatar
Default Re: No spark??? (cstay)
Try your main relay
Old Jul 28, 2004 | 08:05 AM
birz's Avatar
I will try out a new main relay, I've found one for 20$ I'll keep you updated.
Old Jul 29, 2004 | 01:56 PM
birz's Avatar
update:
I have changed the main relay,,, no luck still not getting any spark btw I didnt tap any wires,, I think I'm going to buy a brand new dizzy,,, but if it still get not spark I'm kinda screwed,,,, why am I so unlucky with my car?
Old Jul 29, 2004 | 02:01 PM
torr's Avatar
check underdash fuse
Old Jul 29, 2004 | 02:25 PM
birz's Avatar
Default Re: No spark??? (torr)
oh, an I defintly hear the CLICK of the main relay,, and hear my fuel pump,, so what would I be checking for, in checking the fuse???
Old Jul 29, 2004 | 06:17 PM
birz's Avatar
*******BIG UPDATE!!!!*********
the car is running again woooooot!!!!!
finally after hours and hours of searching I found what the problem was, what is better than pic to show you what was it:
The faulty bastard, you can see that on the top it looks like it's burnt
now the bastard deserves what he deserves:
Yahooooo I'm so happy you can't even imagine how happy I am now
now I only need my wideband and tune that bitch!!!!
end of story. Thanks for all who helped me out in this story.
Modified by birz at 7:55 PM 7/30/2004
GTFODave
Mar 24, 2010 06:14 AM
Keno20
Jan 26, 2009 10:10 PM
oakpwr
Jan 20, 2007 06:00 PM
fwdftw
52
Sep 5, 2006 11:31 PM
Hans
Mar 4, 2003 03:02 AM
