obd0 engine management?
Old Dec 9, 2004 | 05:54 PM
LSVtechnologytur...'s Avatar
Default obd0 engine management?
hey everyone, i have a 91 integra that im doing a turbo build on, but im not sure what i should use for engine management. I was planing on using turboedit until i heard that its not that great at higher boost pressures. my power goals are 300whp and 200tq. out of a t3/to4e .50trim @ around 1bar (or what ever it will take) So what do you think i should use? I dont have alot to spend on it, but i do want my car running good. TIA
Old Dec 9, 2004 | 07:15 PM
USDM 4G VTEC's Avatar
Default Re: obd0 engine management? (vtec'n)
turbo edit is good enough
it does basically 90% what uberdata does
go ahead and get it, get a 3 bar map sensor and u shall be good to go
Old Dec 9, 2004 | 07:16 PM
civickiller's Avatar
Default Re: obd0 engine management? (USDM 4G VTEC)
switch to obd1 and use uberdata
Old Dec 9, 2004 | 07:23 PM
Default Re: obd0 engine management? (civickiller)
what would the advantages of using uberdata be?
Old Dec 9, 2004 | 07:26 PM
93turbo16's Avatar
I think there is more support for it, atleast that is my point of view, also it is a very user friendly program. If you do some research.
br8crumb
Engine Management and Tuning
10
Jun 29, 2014 04:51 PM
m!n!-ME
Nov 22, 2006 06:02 AM
hany
Nov 13, 2006 03:53 PM
turbociv
Sep 7, 2004 07:26 PM
