Test Pipe or Cat!!!!!!!!!!!!
Old Dec 6, 2004 | 11:08 PM
POWERINTEGRA's Avatar
Default Test Pipe or Cat!!!!!!!!!!!!
I just wonder how many of you out there are actually using you stock cat on your turbo set up and why?
For those using a test pipe why and when to use one. What are really the benefits did you get big power gains after you went from your stock cat to the test pipe. What is the best diameter to use or is there something else besides a test pipe.
Also is this only for race set up or full built, the street or what?
I see a lot of people using the stock cat on stock motors using only a kit!
Now on to what I know:
I know that most of the time the stock cat will kill a lot of power for a full built turbo set up. because air preassure starts going out it gets to the cat and is like it makes a stop and then continues out really fast and this kills power. I would like to help the people out there and see what you are using.
Thanks
Old Dec 6, 2004 | 11:16 PM
Deluzional's Avatar
Default Re: Test Pipe or Cat!!!!!!!!!!!! (POWERINTEGRA)
I dont know too many people with stock cats, a lot of them run high flow cats from carsound, random technology or some other brand. Keep it environmentally friendly, test pipes smell like **** anyways
Old Dec 6, 2004 | 11:26 PM
sporkcrx's Avatar
Default Re: Test Pipe or Cat!!!!!!!!!!!! (Deluzional)
turbo set up #1-gutted cat
turbo set up #2-gutted cat
turbo set up #3-stock cat
turbo set up #4-going back to the gutted cat
Old Dec 6, 2004 | 11:28 PM
iiilgsrlll's Avatar
Test pipe for sure. You will not regret it. Sure, people will say hug a tree get a cat. Whatever. I initially dyno'ed at 236hp with the stock cat then a week later with just the test pipe gained 30hp. The dyno graph in my sig shows where it dies off due to restriction. Just be careful be cause you do lean out.
Old Dec 7, 2004 | 02:10 AM
shadow103rd's Avatar
Stock cat until I can convert to OBD1
If I put a test pipe I throw a CEL
Jon
Old Dec 7, 2004 | 06:10 AM
platinum00's Avatar
Default Re: Test Pipe or Cat!!!!!!!!!!!! (shadow103rd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadow103rd &raquo;</TD></TR><TR><TD CLASS="quote">Stock cat until I can convert to OBD1
Jon</TD></TR></TABLE>
I have a secondary o2 senor simulator that will bypass your secondary 02 sesnor.
you can run this on a odbII ecu and get no codes..
platinum.
Old Dec 7, 2004 | 06:42 AM
Evanmb44's Avatar
just ziptie the second o2 sensor securely out of the way....its an inexpensive and quick fix for the time being....and it doesnt throw a code
Old Dec 7, 2004 | 06:57 AM
vtec.dc2's Avatar
not using stock cat but using carsound highflow cat. 20k miles so far with no problems.
Old Dec 7, 2004 | 08:39 AM
Default Re: Test Pipe or Cat!!!!!!!!!!!! (vtec.dc2)
anybody try to dyno on this high flow cats for example the carsound one?
I know a stock cat is killing power
for example I saw a car dyno 195hp the power goes up and all of a sudden drops. It was the cat the one that did not allow to make power it was restricting the air flow.
Then the guy put a test pipe and his dyno was 250 hp and that was all he replaced.
But I haven seen one with the high flow cat does it flow the same??
Old Dec 7, 2004 | 08:43 AM
vtec.dc2's Avatar
never dynoed before after.. but i made 260whp with 2.5" ehxuast and 2.5" high flow cat.. i'm sure i can gain some hp from removal but that isn't a concern
Old Dec 7, 2004 | 01:44 PM
boosted-delslow's Avatar
Default Re: Test Pipe or Cat!!!!!!!!!!!! (Evanmb44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evanmb44 &raquo;</TD></TR><TR><TD CLASS="quote">just ziptie the second o2 sensor securely out of the way....its an inexpensive and quick fix for the time being....and it doesnt throw a code</TD></TR></TABLE>
It will eventually throw a code!!!
Old Dec 7, 2004 | 01:49 PM
iiilgsrlll's Avatar
Default Re: Test Pipe or Cat!!!!!!!!!!!! (boosted-delslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted-delslow &raquo;</TD></TR><TR><TD CLASS="quote">
It will eventually throw a code!!!</TD></TR></TABLE>
I can attest to that. Double bunging the secondary sensor worked for me.
PurpleAccord88
Feb 3, 2007 08:32 PM
DpQInteg
May 13, 2006 07:40 AM
hatchii
Nov 25, 2002 11:46 PM
808State
May 14, 2002 11:12 AM
vtec power
Jul 30, 2001 09:32 AM
