what oil and grade are you using?
Old Dec 7, 2004 | 12:48 PM
ThefirstPACT's Avatar
Default what oil and grade are you using?
yeah answer!
Old Dec 7, 2004 | 01:10 PM
hondaguyef's Avatar
Default Re: what oil and grade are you using? (ThefirstPACT)
Mobil 1
5w30
Phil
Old Dec 7, 2004 | 01:21 PM
TheShodan's Avatar
Moderator
Castrol Syntec... 10w/30
Went back to mobil 1 Tri Synth... 10w/30
Old Dec 7, 2004 | 01:25 PM
RacerXI's Avatar
Default Re: what oil and grade are you using? (hondaguyef)
Mobil 1 fully syn. 10/30
CivicEJ1's Avatar
10w30
Old Dec 7, 2004 | 01:38 PM
SOHC_MShue's Avatar
Default Re: what oil and grade are you using? (CivicEJ1)
mobil 1 10w/30 synthetic.
Old Dec 7, 2004 | 01:39 PM
AlphaMike's Avatar
Default Re: what oil and grade are you using? (SOHC_MShue)
Pennzoil 10W40 in the cold, 20W50 in the heat
Old Dec 7, 2004 | 02:35 PM
HXMan's Avatar
Belgium made Castrol Syntec 5w40. It has a higher ACEA rating then the normal stuff I believe.
Old Dec 7, 2004 | 02:50 PM
Maxime's Avatar
Default Re: what oil and grade are you using? (HXMan)
Castrol Syntec 5w50.
Old Dec 7, 2004 | 03:22 PM
hondaguyef's Avatar
Default Re: what oil and grade are you using? (AlphaMike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaMike &raquo;</TD></TR><TR><TD CLASS="quote">Pennzoil 10W40 in the cold, 20W50 in the heat</TD></TR></TABLE>
Mike, how long have you been running Pennzoil? (Not busting on it BTW) I have torn down 2 engines that used pennzoil and both had a yellowish orange tint on basically every component the oil touched. I am not saying that it was bad or good just curious if you have torn down an engine of your own and found this as well?
Phil
ps. sorry for being off topic.
Old Dec 7, 2004 | 03:26 PM
careawholelot's Avatar
mobil 1 synthetic 15-40 for turbocharged engines
Old Dec 7, 2004 | 08:48 PM
jason190's Avatar
Default Re: what oil and grade are you using? (careawholelot)
I know turbonetics recommends 20w50
Old Dec 8, 2004 | 02:04 AM
TurboBumblBee's Avatar
Default Re: what oil and grade are you using? (jason190)
a guy at work was telling me that he uses castrol 5w50 in all his cars and has never had a problem with it.. he recommended that i use it also on my car but i was unsure if it would be good for the built motor and turbo..
does anyone have any input on it? btw, he uses it on his turbo diesal, 94 acura legend, and his expedition
Old Dec 8, 2004 | 03:24 AM
BoostedCivicSedan's Avatar
Default Re: what oil and grade are you using? (TurboBumblBee)
Castrol GTX 10x30 all day
Old Dec 8, 2004 | 04:25 AM
drvfast's Avatar
10w30
Old Dec 8, 2004 | 04:29 AM
VisualAutoMotoring's Avatar
Default Re: what oil and grade are you using? (drvfast)
Valvoline Racing 20W50...also helps that I got a crapload free
But yea it works well on turbo'ed applications. Ive tried synthetic and just comes out too thin and i would guess cause lots of friction
Old Dec 8, 2004 | 05:07 AM
FOrSfEd's Avatar
Default Re: what oil and grade are you using? (Hybrid-Performance.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com &raquo;</TD></TR><TR><TD CLASS="quote">Valvoline Racing 20W50...also helps that I got a crapload free
But yea it works well on turbo'ed applications. Ive tried synthetic and just comes out too thin and i would guess cause lots of friction</TD></TR></TABLE>
I would agree with above, I've been using mobile1 10w30 switched to mobile 1 15w50 and still came out to thin. So I'm going to try castrol part synthetic and see how that works out.
Old Dec 8, 2004 | 05:11 AM
USDM 4G VTEC's Avatar
Valvoline Syn-blend 10-30
Old Dec 8, 2004 | 05:17 AM
fjt's Avatar
fjt
Default Re: what oil and grade are you using? (RacerXI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerXI &raquo;</TD></TR><TR><TD CLASS="quote">Mobil 1 fully syn. 10/30</TD></TR></TABLE>
Old Dec 8, 2004 | 05:20 AM
Scean's Avatar
Default Re: what oil and grade are you using? (fjt)
mobile 1 full syn.
10w 30
Old Dec 8, 2004 | 05:21 AM
Default Re: what oil and grade are you using? (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">
I would agree with above, I've been using mobile1 10w30 switched to mobile 1 15w50 and still came out to thin. So I'm going to try castrol part synthetic and see how that works out. </TD></TR></TABLE>
how good is it to switch from mobil1 10w30 synthetic back to part synthetic or even regular oil???
where do you buy the valvoline racing 20w50?? and is the racing 20w50 sythetic or regular? and how often do you need to change your oil using this oil?? its almost time to change my oil on my turbo'ed hatch and im sick of adding oil to it all the time cause its burning up and thin..
Old Dec 8, 2004 | 05:50 AM
PolyPill's Avatar
Anyone used that Mobil1 synth 0W-20? They list newer honda/acuras and turbo engines for this to be used in on the bottle, although that's probably marketing
Old Dec 8, 2004 | 06:01 AM
EKhothatch's Avatar
Mobil 1 10w30
I'm trying Mobil 1 5w30 for the winter.
Old Dec 8, 2004 | 07:21 AM
FOrSfEd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboBumblBee &raquo;</TD></TR><TR><TD CLASS="quote">
Not completly sure, but I can't see it doing any in depth damage to my engine. Maybe someone will chime in.
Old Dec 8, 2004 | 07:55 AM
StrokedPSI's Avatar
mobil 1 20w50
