D16y8 stock valves safely rev to?
I have searched but have not found any concrete answers. I would like to know how high i can take my stock d16y8 valves before i run into problems. I am running an SC50 with crower springs and retainers along with the stage 2 cam but do i need to look into valves too? thanks for the help in advance
Re: D16y8 stock valves safely rev to? (unsungsohc)
the power will probably drop off before you meet the vavle limit...
im gona say with the setup you have 9000k is the highest you should go safely
Re: D16y8 stock valves safely rev to? (pornstarSR)
Yeah I used to rev the z6 to 8500 all day long, stock block... Never broke anything because of that. But the above post is right, power will fall off before you overwhelm your valve train. The z stops making power around 7500/8k. You could probably get more up top by retarding the cam, if my brain is working right.
Matt
Matt
Re: D16y8 stock valves safely rev to? (Johnyquest)
great! that's all i was looking for. i am simply looking to take them to bout 8k or a little higher with some dyno tuning to do like u both said...see where it falls on it's face. thanks again
97_ek_coupe
13
02-13-2014 07:51 AM
