Oil Pan for turbo oil return
Like Title says, does anyone have an oil pan with the oil return put in it for sale? if so i can send paypal payment, or is there a company that sells them already done? Thanks
Re: Oil Pan for turbo oil return (khallbeck)
np..alsou can just tap it yourself,it will be waaaayyy less money than buying a moroso pan.just get a weld on bung/fitting,have the pan drilled to size in spot that you want,then have it welded,and thats it.
http://store.summitracing.com/...N=120
its a -10an weld on fitting..just drill a correctly sized hole,and weld it to your oil pan in the spot you want,and you are good to go
the best way to do it is to use fittings that all bolt together so you don't have to weld on it
you can get all the fittings and braided hoses etc at summit or a place like that
Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpintyperintegra »</TD></TR><TR><TD CLASS="quote">the best way to do it is to use fittings that all bolt together so you don't have to weld on it
you can get all the fittings and braided hoses etc at summit or a place like that</TD></TR></TABLE>
bolt the fitting to the oil pan?how would that work?
i have a bulkhead fitting,then a nut on the back of it.but since i did that i would feel much better just getting it welded so you dont have to worry about it leaking
tapping oil pan
Anyone have a way to show where the pan needs to be tapped. Preferably for a d series. Pics perhaps of where you chose to tap the pan. I only ask because i guess the bung needs to be placed above the level of the oil or something like that.
Stewie
Welding / Fabrication
11-09-2005 08:38 AM
Sinner
10-08-2004 09:21 AM
