Damaged Motor, what to do?
Old Dec 6, 2004 | 03:08 PM
boosted bseries 04's Avatar
Default Damaged Motor, what to do?
Hi, Im still purplexed about my blown motor.
its a boosted b-series, 81mm bore, 9:1 compression. your basic turbo setup tuned on pump gas.
the pistons are shot, plugs look like they have white specs all over them.
Im still wondering exactly what happend? My first indication was that the motor went lean, detonated, and damage was done.
what does everyone have to say about the timing maps, do they look too aggressive, or is that ok? did the motor detonate because it was too lean, or because of the ignition timing. Im looking for answers so I dont have to fork out money to rebuild.
I sent the injectors out to be tested, I hope to have the results back shortly. but they didnt have many miles on them.
attached are the pics:
http://img82.exs.cx/img82/8449/pic175.jpg
http://img72.exs.cx/img72/7218/61-fuel.jpg
http://img90.exs.cx/img90/7917/c5-ign.jpg
http://img89.exs.cx/img89/3510/e8-log1.jpg
Old Dec 6, 2004 | 03:28 PM
beepy's Avatar
Default Re: Damaged Motor, what to do? (boosted bseries 04)
Hmm. Were't you the guy blaming your tuner for blowing the engine?
In any case, compare your timing map:
To the "hack" timing map:
Yours is about 6° less advanced at the high end. Seems fairly safe.
I would say from lack of any other evidence, that the engine detonated from going excessively lean, for any number of reasons. Perhaps an injector was bad. Perhaps an injector pigtail rattled loose. (Has happened to me twice) Perhaps it was the tuner's fault. (Though I am doubtful of that)
williamwillie
Feb 22, 2013 06:43 PM
I4BangN
Sep 7, 2008 09:39 AM
SpoolnByYou
Jan 31, 2006 10:29 AM
Adi Radoncic
Dec 31, 2005 07:41 AM
