timing problem, need help fast please!!!!!
Old Dec 9, 2004 | 07:12 PM
Mr_Bojangles's Avatar
Default timing problem, need help fast please!!!!!
I am trying to set the timing on my car, I think the belt skipped some teeth under boost.
I have the white mark on the crank pulley facing up, now on my AEM cam gear the tooth with the O on it should it be facing straight up or toward the firewall?
Everytime I get it facing the firewall the distributor rotor is on the #2 cylinder.
Old Dec 9, 2004 | 08:31 PM
platinum00's Avatar
Default Re: timing problem, need help fast please!!!!! (Mr_Bojangles)
the cam gear should be facing straight up
platinum.
Old Dec 9, 2004 | 09:21 PM
SOHC_MShue's Avatar
make sure the white mark on the crank pulley is lined up with the little notch on the lower timing cover and make sure the marks on the sides of the cam gear line up with the top of the head.
Old Dec 10, 2004 | 10:59 PM
JdmEKCivic's Avatar
Default Re: timing problem, need help fast please!!!!! (SOHC_MShue)
when you put the belt on try to get a hanger or wire and pull on the spring that's on the tensioner b4 you tighten the bolt, that should get the belt a little tighter
PY2KITR1060
Jul 26, 2022 06:12 AM
Colmsted
Nov 1, 2009 10:50 AM
Mr_Bojangles
Dec 9, 2004 07:17 PM
Todd00
Jun 16, 2003 08:49 AM
agent marlon
Nov 19, 2002 08:32 PM
