1.70 Uberdata Lean with basemap in boost range
Old Dec 10, 2004 | 07:16 AM
juka's Avatar
Default 1.70 Uberdata Lean with basemap in boost range
(Hey folks, just posted here too cuz the Uber site is slow for responses):
It's not just on deceleration (I don't think), cuz I set the Min TPS Trigger to 12.
In the boost range, some numbers are okay, but some are 16.0, 16.4, 16.1, etc.
- 8.7 PSI
- 440cc Delphi injectors (42lb/hr @43.5psi, 320gm/min)
- PLX M250
- I followed the steps to get an LS basemap
- 110 fuel efficiency, .80 ignition retard
Things to try?
Anyone?
Uberdata ROCKS!
Old Dec 10, 2004 | 07:35 AM
FOrSfEd's Avatar
Default Re: 1.70 Uberdata Lean with basemap in boost range (juka)
TRy to up your fuel efficeincy to 120, and add around 5% to the places where it is lean, and smooth it out from there, since I see you have a wideband.
Old Dec 10, 2004 | 07:48 AM
juka's Avatar
Default Re: 1.70 Uberdata Lean with basemap in boost range (FOrSfEd)
ForsfEd:
Thanks. I was gonna try somthing similar, but it bothers me that the basemap was so lean... I'm almost suspecting my injectors, or duty cycle, I don't know.
Anyone else?
Thanks again man.
Old Dec 10, 2004 | 07:49 AM
ScottEK's Avatar
Try tuning maybe?
Old Dec 10, 2004 | 07:52 AM
PM-Performance's Avatar
Default Re: 1.70 Uberdata Lean with basemap in boost range (beta13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 &raquo;</TD></TR><TR><TD CLASS="quote">Try tuning maybe?</TD></TR></TABLE>
exactly. its a basemap. how acurate would you expect it to be ?
93turbo16's Avatar
It was soo lean, because of your boost efficiency, it is also known that 1.7 is a little leaner for whatever reason. I believe because they changed something with the resolution, maybe I am wrong.
Old Dec 10, 2004 | 07:56 AM
TurboJesse
Guest
Posts: n/a
Default Re: (93turbo16)
Um add fuel
Old Dec 10, 2004 | 08:05 AM
juka's Avatar
Default Re: (Mpir3)
Hey, easy guys.
I don't expect the basemap to be perfect, but I DID expect it to be on the rich/safe side. Whoever said that 1.7 tends to be lean -- thanks --- THAT's what kind of info I was after.
Seeing 16's with a basemap made me instantly start to suspect my injectors, that's all.
Thanks for responding tho.
Old Dec 10, 2004 | 08:53 AM
VTC_CiViC's Avatar
Default Re: (juka)
&lt;-- Always starts with 120% effiecency.
Just for giggles, my Uberdata SOHC map was nearly *DEAD ON* on my first burn. Adjusted maybe 2-3% here and here for a linear A/F line, otherwise it was at least 98% accurate for boost right off the bat.
Old Dec 10, 2004 | 10:50 AM
JDogg's Avatar
Default Re: (VTC_resurected_CiViC)
what turbo are you running... i have done a few cars with gt28rs's that required 150% efficecny to get in the right range... change it to 150 and work your way down from there.
Old Dec 10, 2004 | 11:57 AM
tilt's Avatar
uberdata 1.70 stock gsr bin -
120 efficiency, .9 retard, 50psi for the new fuel pressure setting, 450cc injectors. I was running on the lean side under boost. I bumped the fuel pressure on the car about 5psi to get the basemap on the rich side then started to adjust the maps from there. I could have also messed with the efficiency to achieve the same. hth
burks
Apr 30, 2007 02:13 PM
SpeedingHatch
Dec 31, 2005 02:41 PM
The DX Rex
Dec 28, 2004 07:25 PM
turbo*s2k
Feb 25, 2004 10:25 AM
BoostedsiR
Jul 31, 2003 09:19 PM
