CEL light for Vtec pressure switch comes on under boost
Old Dec 8, 2004 | 07:57 PM
shiftgear8000's Avatar
Default CEL light for Vtec pressure switch comes on under boost
well, driving my car regularly I have no codes and the car runs perfect. But under hard acceleration and when boost kicks in, the check engine light comes on, and it's always code 22 (vtec pressure switch). I have a d16z6 w/ uberdata.....anyone else ever have this issue??
-jase
Old Dec 8, 2004 | 08:14 PM
m R g S r's Avatar
Default Re: CEL light for Vtec pressure switch comes on under boost (shiftgear8000)
Same thing happened to me a while back, with my stock gsr motor. I was low on oil. . You sure it's not code 23? I could have sworn it was 23. Ohh well, that was over a year ago.
And BTW, I cracked a sleeve and all the ringlands the next day. I don't think it was related, but w/e.
ComputerJLT's Avatar
your oil pressure may be low
are you running a restrictor in your oil line?
Old Dec 8, 2004 | 08:30 PM
GEN2TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shiftgear8000 &raquo;</TD></TR><TR><TD CLASS="quote">well, driving my car regularly I have no codes and the car runs perfect. But under hard acceleration and when boost kicks in, the check engine light comes on, and it's always code 22 (vtec pressure switch). I have a d16z6 w/ uberdata.....anyone else ever have this issue??
-jase</TD></TR></TABLE>
I am having the exact same problem.
I am running a restrictor in my oil aswell, which was made even smaller to hopefully fix the problem, and it still happens?
Bump for some more input on this issue.
Old Dec 8, 2004 | 08:31 PM
Bailhatch's Avatar
Default Re: CEL light for Vtec pressure switch comes on under boost (ComputerJLT)
I'd say low oil or messed up pickup. I get that code every now and then if I'm down 1/2 a quart and take this one particularly fun exit ramp at around 85. God Azenis are fun
Old Dec 9, 2004 | 07:40 AM
GEN2TEG's Avatar
Default Re: CEL light for Vtec pressure switch comes on under boost (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">I'd say low oil or messed up pickup. I get that code every now and then if I'm down 1/2 a quart and take this one particularly fun exit ramp at around 85. God Azenis are fun </TD></TR></TABLE>
Low oil wasn't the case as there was plenty. So you think it may be oil pump pick up?
Old Dec 10, 2004 | 11:41 AM
GEN2TEG's Avatar
More help anyone?
Old Dec 17, 2004 | 06:57 PM
Default Re: (GEN2TEG)
more info please.....this problem is really pissin me off lol. Is it possible the vtec solenoid is bad??? The code goes away as soon as I shut the car off and turn it back on. But it's really pissin me off lol.
-jase
Old Dec 17, 2004 | 07:34 PM
93turbo16's Avatar
You can try cleaning the ground for the oil pressure switch. that in some cases gets corroded and will make it do that.
Old Dec 18, 2004 | 05:15 AM
integracivic94's Avatar
Default Re: (93turbo16)
i had this same problem and it turned out that it was my apexi vafc the blue wire was hooked up wrong!
Old Dec 18, 2004 | 06:08 AM
Default Re: (integracivic94)
would having too much oil in the car also cause this problem???
-jase
Old Sep 4, 2005 | 11:32 PM
OMG B16's Avatar
Default Re: (shiftgear8000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shiftgear8000 &raquo;</TD></TR><TR><TD CLASS="quote">would having too much oil in the car also cause this problem???
How about your tune your car?
Modified by Sick00SiCoupe at 1:48 AM 9/6/2005
Old Sep 5, 2005 | 09:31 PM
boosted k20's Avatar
Default Re: (Sick00SiCoupe)
ehhhh disable Vtec Pressure switch in uberdata but make sure u have an oil pressure gauge so u know u r get n good pressure
EF-ingB16
Nov 6, 2011 10:04 AM
ncsuprelude
Nov 13, 2006 08:24 PM
drudy
Aug 26, 2005 12:20 PM
ninety9ex
Feb 11, 2004 12:54 PM
Blake97GSR
Nov 7, 2003 06:01 AM
