fuel return line
Old Dec 9, 2004 | 10:36 PM
imthedude's Avatar
Default fuel return line
yeah so im redoing all of my fuel lines because they are rusted and blown out. I want to do the feed -10 and the return -6 . Is the return going to be any problem?
thanks in advance
Old Dec 10, 2004 | 10:04 AM
pissedoffsol's Avatar
25 Year Member
Default Re: fuel return line (imthedude)
it will be a bitch, because the return line turns into a brass or something hardline on the firewall. basically, theres no way to screw in a fitting to it or anything. i remember there being a thread a while back on this where someone actually kinda tapped the thing to accept a fitting. try doing a search on that
Old Dec 10, 2004 | 10:20 AM
msmotorsports's Avatar
-6 is perfectly fine for a return. That is what exactly we are using on our drag car. Let me know if you need any fittings and line. I'm selling a ton of new and used Aeroquip fittings cheap at https://honda-tech.com/zerothread?id=1076280.
Old Dec 10, 2004 | 12:48 PM
tgreaves's Avatar
Default Re: fuel return line (msmotorsports)
I would say an an8 feed and an6 return.. How much power are you planning to make with your setup..
Old Dec 11, 2004 | 12:45 AM
Tchleung's Avatar
When the line becomes a hardline, just cut it off at the hardline, then flare the line out then put a fitting on there
Old Dec 11, 2004 | 07:45 AM
B18c1turboedEK's Avatar
Default Re: (Tchleung)
HOw about a 8an feed line and 8an return line?? is that to big?
Just asking becasue i got a great deal on some 8an line.. I plan on putting out atleast mid 550 to 650HP hopefully!!!!
Old Dec 11, 2004 | 08:11 AM
tgreaves's Avatar
Default Re: (B18c1turboedEg)
If you have all an8 line then use it.. AN8 feed and AN6 return is more than enought flow for the power you want to put out..
Old Dec 11, 2004 | 06:43 PM
imthedude's Avatar
yeah im redoing all of the line since both my return and feed are so rusted there spraying gas every where
mrxlazy
Feb 23, 2008 10:41 AM
elite01
Honda Civic (2001 - 2005)
Sep 27, 2007 11:35 AM
HamiltonRex
Apr 17, 2006 05:17 PM
PrecisionH23a
Jul 17, 2002 07:20 PM
