resistor.. which is better???? searched..
Old Dec 7, 2004 | 03:01 PM
guywitaDA's Avatar
Default resistor.. which is better???? searched..
I have a question..... when goin boost people are using dsm injectors they need a resistor box/resistors. Which is better the box off of a older honda or the resistors from radioshack??
Old Dec 7, 2004 | 03:12 PM
donkiman's Avatar
Default Re: resistor.. which is better???? searched.. (guywitaDA)
i ran into the same question a while back. i found out the hard way. i wired up the resistored, soldered them and wrapped them look perfect but whenever youd tap them theyd shoot a different frequency. so no i would never advise those to go on anyones car. for $15 you can get an oem hondata resistor box. the older ones work fine, thats what im using.
Old Dec 7, 2004 | 03:27 PM
oxSLEEPERxo's Avatar
Default Re: resistor.. which is better???? searched.. (donkiman)
get a resistor box
Old Dec 7, 2004 | 04:37 PM
CivicEJ1's Avatar
Are you sure!...mine seems to work fine.....
10ohm10watt resistors..radioshack...
Old Dec 7, 2004 | 04:59 PM
donkiman's Avatar
Default Re: resistor.. which is better???? searched.. (CivicEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure!...mine seems to work fine.....
10ohm10watt resistors..radioshack... </TD></TR></TABLE>
those are the same ones i used. it is possible that you just have them mounted more securly than i did but for the price of an oem resistor box i'd say its worth it.
Old Dec 7, 2004 | 07:08 PM
Syner-G-Racing LLC's Avatar
I dont know what kind of resistors you used but if you used the 1/4 watt wire wound resistors that was your problem...you need sand block resistors. I run 550's on mine no problem...what did you wrap them in ? I have mine in a project box from radio shack, not much different from the oem box except their inline instead of ganged.
JDM MonopolyMan
Nov 21, 2005 11:28 AM
smokinsi
Sep 18, 2005 06:30 PM
RACEPAK
Jul 20, 2005 12:40 PM
warwagon
Mar 2, 2004 08:34 PM
