dsm injector boring seals
Old Dec 9, 2004 | 04:02 PM
b18c1wes's Avatar
Default dsm injector boring seals
do i really have to do this inside the intake manifold... is there any other way to do it? (btw i just realized how i spelled to bore out the seals boreing)
Old Dec 9, 2004 | 04:20 PM
MooreBoost's Avatar
Default Re: dsm injector boring seals (b18c1wes)
You only have to bore out the seals, just pop them out.
Old Dec 9, 2004 | 05:13 PM
adseguy's Avatar
Default Re: dsm injector boring seals (tegunderpressure)
Yeah you really have to bore them out.
Not hard to do and not hard to mess up if you have a dremel tool and 30minutes of time
Otherwise they won't fit correctly (or at all) and the you REALLY have problems
Old Dec 9, 2004 | 05:19 PM
4_door_teg's Avatar
For my 450's in a 1st gen jdm b16 I ordered a set of o-rings from a 95 vtec delsol and the injectors fit perfectly inside. The rings themselves didnt fit my IM though so I used a bench grinder and shaved them down abit, fit nicely.
Old Dec 9, 2004 | 07:05 PM
Alchemist's Avatar
Default Re: (4_door_teg)
I slid them over the sanding disc of the dremel. Then I spun them on a piece of sandpaper and slowly shaved off the outsides. Just be careful that you dont over do it. Also dont spin them too fast or they might fly off any youll have to spend $15 to buy another one.
Old Dec 10, 2004 | 12:01 AM
Calvinator's Avatar
Default Re: (Alchemist)
Ive seen a few people around here that said they dont even bore out there seals. They just shoved the injector into the o ring and as the fuel rail was being bolted down, it pushed it down and sealed.
For my setup, I just bored it out with a dremel.
Old Dec 10, 2004 | 12:23 AM
NightRiderS2K's Avatar
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1wes &raquo;</TD></TR><TR><TD CLASS="quote">(btw i just realized how i spelled to bore out the seals boreing)</TD></TR></TABLE>
OFF TOPIC: Well if you want to realize and ask yourself, "Was I grammatically correct in spelling out boring as present tense of bore? Wait, no its boreing."
<FONT SIZE="8">DOH!!</FONT>
You got it right the first time buddy. When you were little, didn't you learn to always drop the "e" when adding "ing"?
I know, I know, this isn't Grammar school.
Old Dec 10, 2004 | 07:37 PM
b18c1wes's Avatar
Default Re: dsm injector boring seals (NightRider-gsR)
just seemed wrong and i didnt want to belittle my thread calling it boring heh... im a little unclear as to boring them out is there any precision or just ball park untill they are flush..this is my first injector experience if you cant tell already.... gotta start somewhere i guess.. what i meant about doing this inside the manifold is that homemadeturbo.com said its easier to do in a intake manifold. but there has to be another way like mentioned just a little more detail
Old Dec 10, 2004 | 07:51 PM
In-N-Out Burger
Most of the people who have replied already gave out great suggestions. I personally have 450s though I didn't have to bore it out since someone already did it for me.
Anyhow, if I would do it and I don't want to bore it while inside the intake manifold, I would follow Alchemist method and use a dremel.
Old Dec 10, 2004 | 08:04 PM
b18c1wes's Avatar
thats the recomendation by homemadeturbo use a dremel inside of the intake manifold or one laying around(dont have one laying around)... i understand using a dremel is what i need to do but what is the process ..Alchemist gave his process sounds very effective and im not so sure i understand how it bores them out seems like it would just shrink down the sides from the outside in or maybe i just read it wrong ....im asking if theres other ways to do it... ive been aware of using a dremel from the start....
Old Dec 10, 2004 | 09:59 PM
InTeGrA B18b1's Avatar
the first time i put the seal on the injector and tried to put it on, not so smart. then i thought about putting it on the IM first lol. YOu can just shove it in if you put some oil around the injector, it should go in fairly easy. If you dont have a dremel you can use a razor blade to slightly trim the sides until you got a snug fit. Oh yea after you put it in put in 10 watt 10 ohm resistors and after you install it check for leaks, and melting wire or defective restistors. Good luck man
mikegeezy
Mar 5, 2007 09:10 PM
FrOsTwHiTeDC4
Jan 2, 2007 07:44 PM
importdude2000
Apr 20, 2006 12:50 PM
Pikachu
Aug 13, 2005 01:55 PM
djnikko
Oct 13, 2003 06:58 PM
