open dp/o2 question
Old Dec 8, 2004 | 05:24 PM
coupon's Avatar
Default open dp/o2 question
i plan on running a full 3" open dp. im wondering is i have the wideband sensor about 19"s away from the turbo outlet and 10"s away from the end of the dp, will i get a good/accurate reading? or is it to close to the end of the end of the dp and will get a bad reading since it'll mix in with fresh oxygen?
Old Dec 8, 2004 | 05:28 PM
PureTeg420's Avatar
Default Re: open dp/o2 question (slowredhybrid)
I have been running open downpipe for probably 6 months now, and every once and a while if I'm barely on the throttle (think -20 vac), the a/f reading will be off. But as soon as i push the throttle just a little bit (-18 vac) the reading is where it should be. Under any boost conditions the readings are always consistent and accurate. btw my wb02 placement is similar to yours, maybe a little bit further in on the downpipe
Old Dec 8, 2004 | 05:34 PM
coupon's Avatar
Default Re: open dp/o2 question (PureTeg420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PureTeg420 &raquo;</TD></TR><TR><TD CLASS="quote">I have been running open downpipe for probably 6 months now, and every once and a while if I'm barely on the throttle (think -20 vac), the a/f reading will be off. But as soon as i push the throttle just a little bit (-18 vac) the reading is where it should be. Under any boost conditions the readings are always consistent and accurate. btw my wb02 placement is similar to yours, maybe a little bit further in on the downpipe</TD></TR></TABLE>
hmm thanks for the quick responce. what wbo2 are you running? and how much further is the end of your downpipe from where your wbo2 is? please check for me lol!!!
Old Dec 8, 2004 | 05:46 PM
fafsa's Avatar
would also like to know this, since ill be running an open dp too
Old Dec 8, 2004 | 06:11 PM
PureTeg420's Avatar
Default Re: open dp/o2 question (fafsa)
My car is too low to see anything. Imagine where the o2 sensor is on a stock header, well my wb02 sensor is right in front of that, probably about 10- 11in from the end of the downpipe. And I am running the bosch sensor for the Techedge 1.0 kit.
Old Dec 9, 2004 | 10:47 AM
coupon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PureTeg420 &raquo;</TD></TR><TR><TD CLASS="quote">My car is too low to see anything. Imagine where the o2 sensor is on a stock header, well my wb02 sensor is right in front of that, probably about 10- 11in from the end of the downpipe. And I am running the bosch sensor for the Techedge 1.0 kit.</TD></TR></TABLE>
alright sounds good, anyone else?
Old Dec 9, 2004 | 08:56 PM
crex23's Avatar
Why is the o2 bung down at the very end of most downpipes, when the o2 sensor on headers or stock mani is up next to the top?
notsolfast
Engine Management and Tuning
13
May 3, 2012 10:37 AM
Silvertc
Dec 7, 2010 10:42 AM
portenio78
Jun 1, 2006 04:00 PM
92HB_HB
May 11, 2005 06:06 AM
Iamhonda
Sep 11, 2003 06:42 PM
