Oil Line Map
Old Dec 6, 2004 | 02:58 PM
EkHatch1's Avatar
Default Oil Line Map
Like title says, does anyone know a good detailed map explaining the oil return and feed kit, as far as if you need to "T" and stuff like that. Also how to hook up to back of the block, Thanks alot all help is wanted.
Old Dec 6, 2004 | 03:04 PM
SOHC_MShue's Avatar
Default Re: Oil Line Map (khallbeck)
you just put a t on the back of your block. With the middle branch of the t run the feed line to your turbo and on the other end put your stock oil pressure sensor on. Then the oil return just goes from the turbo to your oilpan. If you want to play it safer you could run a line going from your block to the T which you can mount on your firewall instead of having it directly on the block.
Old Dec 6, 2004 | 03:12 PM
Frozen E's Avatar
H-T White Ops
get an adapter fitting from tunertoys.com
Then buy the line kit from Flamenco-T on here
Painless oil line install. It's what I'm running and couldn't be happier.
ÁrniMkv
Feb 10, 2012 07:02 AM
stealthmode62
Oct 3, 2011 06:14 AM
95whitegizzer
Jul 12, 2006 11:59 AM
zbower7
May 14, 2004 01:42 PM
GSR x13
Dec 1, 2003 10:52 PM
