GT SERIES water cooled turbo lines?Pics???Advice????
I've read mixed views aboout where to tee off lines for the coolant lines on a water cooled turbo.....near throttle body and heater core lines. Does one have an advantage over the other and Anyone have pics of their setup
Re: GT SERIES water cooled turbo lines?Pics???Advice???? (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid »</TD></TR><TR><TD CLASS="quote">tb</TD></TR></TABLE>
that's where I got my coolant to flow into my turbo.
Re: GT SERIES water cooled turbo lines?Pics???Advice???? (11psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI »</TD></TR><TR><TD CLASS="quote">Do you have to run the coolant lines for the GT turbos?</TD></TR></TABLE>
No.
On my D series, there is a small water hose that runs from the intake manifold to the throttle body. You throw that hose away and run a water line from the manifold to the turbo, then the other turbo line to the throttle body. Piece of cake.
No.
Re: (O3DigitalBath)
_____________________________$$$____$$____________ _____$$$__________ _$$$$$$$$$$$$$___$$__________$$$__$$$$____________ ___$$$$$$$$_______ $$$$$$$$$$$$$$$_$$$$________$$$$__$$$$___________$ $$_$$$$$$$$$$_____ $$_$$$____$$$$$_$$$$________$$$$__$$$$__________$$ $$__$$$$$$$$$$____ __$$$$_____$$$$_$$$$_______$$$$___$$$$_________$$$ $$__$$$$_$$$$$$___ _$$$$$___$$$$$__$$$$_______$$$$___$$$$$______$$$$$ $$__$$$$___$$$$$__ _$$$$__$$$$$____$$$$_______$$$$__$$$$$$_____$$$$$$ $___$$$$____$$$$__ _$$$$$$$$$______$$$$______$$$$___$$$$$$$__$$$$$$$$ $___$$$_____$$$$__ $$$$$$$_________$$$$______$$$$___$$$$$$$$$$$$__$$$ ___$$$$_____$$$$__ $$$$$$$_________$$$$_____$$$$____$$$_$$$$$$$___$$$ ___$$$$____$$$$___ $$$$$$$$$$$_____$$$$_____$$$$____$$$___$$$____$$$$ ___$$$___$$$$$$___ _$$$_$$$$$$$$___$$$$____$$$$$____$$$__________$$$_ ___$$$$$$$$$$_____ _$$$_____$$$$$___$$$$__$$$$$$____$$$__________$$$_ __$$$$$$$_________ _$$$____$$$$$$___$$$$$$$$$$$____$$$$__________$$$_ _$$$$_____________ _$$$$$$$$$$$$$____$$$$$$_$$$$___$$$__________$$$__ __$$$_____________ $$$$$$$$$$$________$$$___$$$$___$$$__________$$___ __$$$$____________ $$$$$$$___________________________________________ __$$$$____________ _$$_______________________________________________ __$$$_____________
For Pics
For Pics
Re: GT SERIES water cooled turbo lines?Pics???Advice???? (darkdayz)
For those of you that are water cooled, how much are your coolant temps affected? I'm doing some research into a setup for HPDE's but am afraid 30 minutes of lapping on a water cooled turbo could get way to hot to be able to handle it.
Moderator
Re: GT SERIES water cooled turbo lines?Pics???Advice???? (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">
No.
On my D series, there is a small water hose that runs from the intake manifold to the throttle body. You throw that hose away and run a water line from the manifold to the turbo, then the other turbo line to the throttle body. Piece of cake.</TD></TR></TABLE>
You don't HAVE to, but for longevity of that bearing system, for what you've paid for, you'd better...
No.
Re: GT SERIES water cooled turbo lines?Pics???Advice???? (TheShodan)
I hear that my gt2871r was not cheap. I hurd that tuner toys has a water cooler kit but they are all out of them. does anyone know of anywhere else that you can get one.
Re: GT SERIES water cooled turbo lines?Pics???Advice???? (kevino002)
I don't have any experience with the gt's but i'm imagining with a little amount of fab any small cooler should work. ie one from a bike or even on made for like psor oil. Do you have a bigger radiator and fan though. Because tons of more heat is created by exaust gasses throughout the system than cooling lines on a turbo. If your concerned I'd look at my radiator and fan .
