boost limit
Old Dec 16, 2004 | 10:27 AM
haitech's Avatar
Default boost limit
how much boost can you run on a stock motor before you need to upgrade the exhaust, injector, add on a blow off valve...etc....
Old Dec 16, 2004 | 10:35 AM
SpoolnG2's Avatar
Default Re: boost limit (haitech)
u should run no boost if your not gonna upgrade all those items. Exhaust doesnt matter so much as long as u run open downpipe. You for sure need to upgrade injectors and you for sure need a blow off valve. You should do some research before u put a turbo on your car. Theres a lot more to it then just putting it on and going.
Old Dec 16, 2004 | 11:25 AM
Joseph Davis's Avatar
General rule of thumb, you can run 14.7 psi before needing to install a turbo.
Old Dec 16, 2004 | 11:26 AM
boostjunkie757's Avatar
i can see it now...
compressor surge here we come.
pbzhb
Feb 20, 2008 07:53 AM
JDM_Acccord
Jul 5, 2007 03:24 AM
matt11583
Feb 8, 2006 06:11 PM
Hoodwinked
Sep 2, 2003 06:37 PM
1990hondaHF
Aug 5, 2003 11:54 AM
