should i do low comp pistons and rods to run 12 psi on gsr block with vafc
as title states will this be safe how long will the motor last thanks for the help
Re: should i do low comp pistons and rods to run 12 psi on gsr block with vafc (beerbongskickass)
Instead of spending 800 bucks for rods and pistons to make 270 WHP at 12 psi with a VAFC, spend some money on hondata or any other good engine management and make the same amount of power on less boost with a smoother driving car.
Re: should i do low comp pistons and rods to run 12 psi on gsr block with vafc (civichbb18)
Re: should i do low comp pistons and rods to run 12 psi on gsr block with vafc (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 »</TD></TR><TR><TD CLASS="quote">Instead of spending 800 bucks for rods and pistons to make 270 WHP at 12 psi with a VAFC, spend some money on hondata or any other good engine management and make the same amount of power on less boost with a smoother driving car.</TD></TR></TABLE>
agreed
agreed
Get your tuning in order first before trying to make big power.
ChronicGreenDC2
06-29-2005 11:48 PM
ITR1071
05-22-2002 01:58 PM
