What the hell does this CEL mean?
Old Dec 18, 2004 | 04:35 PM
Boost Addict's Avatar
Default What the hell does this CEL mean?
This is on a 99 Prelude with a Greddy 18G turbo, I am just using the Greddy blue box for managment. I get this CEL as soon as I start the car up, I have no clue what is means:
41 - Primary Heated Oxygen Circuit
Detection Item: Circuit Malfunction
Probable Cause: Open or short in Primary HO2S sensor heater circuit ECM
Any ideas?
Old Dec 18, 2004 | 04:41 PM
RotiEatter's Avatar
Ditto
Default Re: What the hell does this CEL mean? (Boost Addict)
You need a new 02 sensor
Old Dec 18, 2004 | 04:48 PM
Default Re: What the hell does this CEL mean? (RotiEatter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">You need a new 02 sensor</TD></TR></TABLE>
Hmmm. Any idea why it would have gone bad? I have a 3" exhaust and high flow cat, and it has been smelling like **** lately.
Old Dec 18, 2004 | 04:58 PM
boostedcivicsir's Avatar
Mr. Badwrench
if it were a code 45, i would think it was fat or lean,
being a heater circuit, i would go for the o2 being bad.
Old Dec 18, 2004 | 05:29 PM
Tad's Avatar
Tad
Default Re: What the hell does this CEL mean? (boostedcivicsir)
also could be the o2 sensor wiring.
check that, make sure it is in good condition all the way through,
and that it hasn't shorted out anywhere.
if you have a multimeter, you can just do a continuity test.
hook up one test lead to one end of the wire, and one to the other end.
if continuity is good, then you know the wire is solid all the way through.
in which case i'd guess it was the o2 sensor.
Old Dec 18, 2004 | 05:43 PM
Default Re: What the hell does this CEL mean? (Tad)
thanks guys
Old Dec 24, 2004 | 02:21 PM
1Quikgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">also could be the o2 sensor wiring.
in which case i'd guess it was the o2 sensor.</TD></TR></TABLE>
junkspeedproject
Feb 5, 2008 01:44 PM
Myh4tch
Apr 4, 2005 08:34 AM
Ge.ES.AHH
Oct 10, 2004 11:21 PM
gsr_to_the_MAX
Oct 5, 2004 09:38 AM
