air fuel-o2 sensor ?
Old Dec 19, 2004 | 04:27 PM
TURBODC4TEG's Avatar
Default air fuel-o2 sensor ?
ok my air fuel gauge doesn't seem to be working, sometimes when i start the car it goes from rich to lean slowly and at 1 bar at a time. then when driving it doesn't even light up or do anything rarely it just lights up lean then cuts off
i am think my o2 is bad but i don't have any check engine lights
Old Dec 19, 2004 | 04:34 PM
hondaguyef's Avatar
Default Re: air fuel-o2 sensor ? (TURBODC4TEG)
Is it just a narrowband?
Old Dec 19, 2004 | 04:36 PM
Default Re: air fuel-o2 sensor ? (hondaguyef)
its a autometer sport compact ultra lite series/ silver
just one wire to tap into o2 wire
Old Dec 19, 2004 | 04:58 PM
wshondaman's Avatar
I had the same problem with my auto meter gauge. it turns out that the O2 sensor was bad and i had no check engine light. after replacing the O2 sensor the gauge worked just fine. Note: before you go out and buy a new O2 sensor which is very expensive have someone check the voltage output of the o2 sensor. just letting you know what i have experienced. good luck
Old Dec 19, 2004 | 04:59 PM
Default Re: air fuel-o2 sensor ? (wshondaman)
thanks for your help
Old Dec 19, 2004 | 07:32 PM
PrettyLude's Avatar
sounds like o2 sensor is bad as previously stated
dohdoh420
Oct 23, 2006 07:52 PM
GSlowR
Apr 15, 2005 11:20 PM
clutch33
Feb 8, 2004 11:53 AM
david90
Jan 21, 2004 01:34 PM
djnikko
Nov 5, 2003 05:44 PM
