Boost spiking on me like CRAZY...HELP!!!!!!!!
Old Dec 17, 2004 | 01:38 PM
RNPoo7's Avatar
Default Boost spiking on me like CRAZY...HELP!!!!!!!!
So after i fixed my problem, i couldn't boost past 6 psi hence my 1/4 times, now my car spikes like crazy. Few mins. ago i hit 20.7 psi. I am using the Greddy boost controller. Gain was on 0% and the boost start was at 5.5 lbs. Limiter at 10 psi and limiter % was at like 50%.
I checked over my vaccum hoses and they are connected right. So here's where i think it might be the problem:
1) Vaccum hoses are too long
2) Since i had exams and crap, i haven't had time to fix my hoses. Like th eone from the wg to the bov are 2 different size hoses b/c my bov needs a smaller hose than the wg.
3)Thanks to my ridicolously designed manifold, (old lovefab shorty), i had to refabericate all my pipes. So part of the downpipe was redone using crush pipes from the elbow to the dp till i have money to buy a new one. Could that be using pressure build up and causes the air to go back to the turbine and causing the boost spike?
TIA
Old Dec 17, 2004 | 03:02 PM
t04ecvc's Avatar
Default Re: Boost spiking on me like CRAZY...HELP!!!!!!!! (RNPoo7)
What kind of wastegate? What size downpipe, and is it connected to an exhaust?
Pics may help a lil also.
Old Dec 17, 2004 | 03:56 PM
RNPoo7's Avatar
Wastegate is Tial 38mm. HKS ssq bov, 2.5" dp. Turbo is connected to elbow, to dp, to 2.5"-3" reducer to 3" flex pipe to 3" thermal exhaust.
Lovefab shorty manifold, Precision 880cc injectors
Old Dec 17, 2004 | 04:40 PM
SOHC_MShue's Avatar
yikes 20.7 psi is scary
Old Dec 17, 2004 | 04:48 PM
RNPoo7's Avatar
Default Re: Boost spiking on me like CRAZY...HELP!!!!!!!! (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">yikes 20.7 psi is scary </TD></TR></TABLE>
yah tell me about it man.
Old Dec 17, 2004 | 05:01 PM
oxSLEEPERxo's Avatar
what psi spring do you have in your tial wastegate?
Old Dec 17, 2004 | 05:14 PM
RNPoo7's Avatar
Default Re: Boost spiking on me like CRAZY...HELP!!!!!!!! (oxSLEEPERxo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">what psi spring do you have in your tial wastegate?</TD></TR></TABLE>
I was told it's a .6 bar so about 8.7 psi.
Old Dec 17, 2004 | 05:27 PM
t04ecvc's Avatar
First thing I would do is remove the boost controller from the equation. See if the wastegate is controlling boost correctly on its own.
Old Dec 17, 2004 | 05:58 PM
JdmEKCivic's Avatar
Default Re: Boost spiking on me like CRAZY...HELP!!!!!!!! (t04ecvc)
open the wg and check the color of the spring to make sure it is a .6 bar i think it should be red it might be wrong.
Old Dec 17, 2004 | 05:59 PM
RNPoo7's Avatar
Default Re: Boost spiking on me like CRAZY...HELP!!!!!!!! (JdmEKCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEKCivic &raquo;</TD></TR><TR><TD CLASS="quote">open the wg and check the color of the spring to make sure it is a .6 bar i think it should be red it might be wrong.</TD></TR></TABLE>
But in theory, i should be boost spiking if it's over .6 bar spring, right?
Old Dec 17, 2004 | 06:00 PM
RNPoo7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t04ecvc &raquo;</TD></TR><TR><TD CLASS="quote">First thing I would do is remove the boost controller from the equation. See if the wastegate is controlling boost correctly on its own.</TD></TR></TABLE>
I turned off the boost controller and gave it a run and it still spikied. so i know the boost controller isn't the problem.
Old Dec 17, 2004 | 06:04 PM
B16CRXT's Avatar
Would the fact that he has the stock MAP sensor have anything to do with it?
Old Dec 17, 2004 | 06:17 PM
Boosted2K's Avatar
Default Re: Boost spiking on me like CRAZY...HELP!!!!!!!! (B16CRXT)
Try taking a small piece of hose that you KNOW has no cracks, holes etc. and run it directly from the bottom port of the W/G to the nipple on the turbo, and give it a test run. and leave the top port of the W/G open
if it doesn't spike then you know its from the boost controler down.
if you find out its the boost controler or the install of the lines, inspect the lines and try hooking it up using the internal wastgate diagram, run the line to the bottom port of the wastegate, and leave the top port open
My Spec II holds rock solid in this configuration
Old Dec 17, 2004 | 07:56 PM
SickAssLy's Avatar
its probably your vacuum line routing to the wrong thing on the wastegate
send me a pic of your engine...
Old Dec 24, 2004 | 04:11 PM
RNPoo7's Avatar
ok man, this is really pissing me off. It just spiked 14-16 again. I'm still working on the pics. i'll have me asap.
But I dont know what to do anymore. I checked my hoses and replaced most of them.
Old Dec 24, 2004 | 05:43 PM
W O T's Avatar
Default Re: (RNPoo7)
Well why the **** are you beating on your car when you know you have spike problems
Doesnt take a week to take pictures
Seriously, if you knw you have a problem, boosting 20+ psi on Im assuming stock block b series, your pissing your engine away
Old Dec 24, 2004 | 09:43 PM
RNPoo7's Avatar
hello, i'm adjusting my boost controller settings and testing them...i'm doing boosting unless i'm testing!!!!
And yes, it's a stock B18c1. After fixing few vacuum hoses. I got it to only spike to about 16 psi. No more 19 and 20 BS but problem still not solved.
I don't have a camera. Trying to borrow one from my friends.
Old Dec 24, 2004 | 10:45 PM
AspectIndustries's Avatar
Try opening your Wastegate and see if the DIAPHRAM is Broken of some sort. If it is, this will let boost SPIKE real HIGH.... Best bet, if all things are eliminated.
Old Dec 25, 2004 | 05:54 AM
rondigs's Avatar
Default Re: (synik)
I had a 38mm tial that was forever spiking. Changed to a 44mm tial and what da ya know...no more spiking.
However, your setup is probably a bit different than mine. Check over the lines and make sure everything is routed correctly.
Old Dec 25, 2004 | 06:57 AM
B16CRXT's Avatar
Default Re: Boost spiking on me like CRAZY...HELP!!!!!!!! (Boosted2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted2K &raquo;</TD></TR><TR><TD CLASS="quote">Try taking a small piece of hose that you KNOW has no cracks, holes etc. and run it directly from the bottom port of the W/G to the nipple on the turbo, and give it a test run. and leave the top port of the W/G open
My Spec II holds rock solid in this configuration </TD></TR></TABLE>
This is the best advice I have seen so far Pete. I think we should try this and see how it goes.
Boposted2K; is your top port open at all times? His goes to the boost controller solenoid. Is that not necesary?
Old Dec 25, 2004 | 08:50 AM
Boosted2K's Avatar
Yes, my top port is open at all times, I run the Profec-B spec II in the internal wastegate configuration (shown in the instructions). The line is run to the bottom port of the Tial W/G.
This method of hook-up was recomended to me by Jason H (Stoopid) during my tuning session, I have been told this is wrong, but it holds boost for me ROCK SOLID, I hear alot of complaints about the spec II, I'd say they are probably 99% user error. This boost controller works fine if you learn how to use it, no need for the over-rated AVCR.
Old Dec 25, 2004 | 09:35 AM
RNPoo7's Avatar
will try that and keep u updated.
Old Dec 25, 2004 | 02:42 PM
B16CRXT's Avatar
I wonder if since Greddy screwed up some terms in the directions, if maybe they screwd up the install diagrams???
Old Dec 25, 2004 | 05:25 PM
Cyphear's Avatar
turn your gain down (mine is at 0%). hook your **** up right.
Old Dec 25, 2004 | 07:34 PM
RNPoo7's Avatar
My gain is at zero percent and my **** is hooked up right according to the Greddy diagrams.
Modified by RNPoo7 at 12:05 AM 12/26/2004
