JRSC on b18 which fuel
Old Dec 15, 2004 | 11:03 PM
- Sim -'s Avatar
Default JRSC on b18 which fuel
hey guys
i just have my jrsc kit received and now i m thinking over the fuel supply for about 6 psi of boost.
will an vacf-2 and a fuel pressure regualator be okay? for beginning?
i can use 440 injectors also.
in the future i m planing aem ems stand alone ecu with 8 to 11 psi of boost.
but for now in the bebinning i just want to know if i can work with afc2 and injectors
thanks
Old Dec 15, 2004 | 11:58 PM
Sonny's Avatar
Default Re: JRSC on b18 which fuel (- Sim -)
If you just got the kit, I would recommend installing the kit as-is and then playing with the electronics after. (assuming the kit is new and/or complete)
It will greatly simplify the number of things that can go wrong.
Do not run the stock pump with the stock injectors though. It won't do more than 75 psi of fuel pressure. You'll need at least 90 with the 6 psi pulley.
Sonny
Old Dec 16, 2004 | 08:06 AM
- Sim -'s Avatar
Default Re: JRSC on b18 which fuel (Sonny)
thanks sonny,
i ll keep that in mind.
Old Dec 16, 2004 | 09:07 AM
hypa's Avatar
well put sonny.
All I can add is to search the forums on some of the other H-T jrsc setups. There's a ton of great info on here regarding the jrsc.
oacrep1
Feb 6, 2006 07:34 AM
AmplifiedGSR
Apr 7, 2004 09:31 AM
DeDonDeRosa
Dec 16, 2002 11:19 AM
Ski2001
Dec 10, 2002 04:36 AM
