440ccm peak&hold injectors - where?
Hi,
i need some 440ccm peak&hold (low resistance) injectors for my b16a1... importparts has some saturated for 76$
is there a chance to get them cheaper?
Thanks
Malte.
Thanks
Malte.
Re: 440ccm peak&hold injectors - where? (hondaguyef)
Can you tell me if there is a shop?
or maybe you have a DSM Part Number for me so i can get them?
do they all fit without problems?
Thanks
Malte.
Thanks
Malte.
Re: 440ccm peak&hold injectors - where? (mrx)
i have another question,
where can i see if a dsm injector fits into my stock b16a1 fuelrail?
are they all the same?
are they low or high impedance?
or can i even use only from special model's or years?
Thanks
Malte.
Thanks
Malte.
dsm injectors are peak and hold. you will want to find dsm blue or black top injectors. They are the 450cc ones. You will just have to bore out the ijnector seals to make them fit your intake manifold. They fit the fuel rail fine. Not sure if a b16a1 is obd o or I, but if it isn't obd I, you will need obd I injector clips. I have these on my 2000 civic and they work great.
Re: 440ccm peak&hold injectors - where? (BME1986)
Thanks,
b16a1 is obd0 so i think i need new injector clips...
i think i can get some from a OBD1 honda (b16a2 i.e.) or is there a cheaper way to get them?
Thanks for your help
Malte.
Malte.
i got mine for like 5 bucks from some kid in my town. Either somebody on here will have them or go to a local junk yard.
What type of fuel management are you going to be using?
fuel management will be something like uberdata ... so i won't get any problems the only thing that was unclear is if the dsm's will fit without any problems...
sounds good. I am running the hack right now, but will be switching to uberdata once I rebuild and boost more than 12psi.
Hi,
yes, because i have a B16A1 with PW0 ecu i wrote some software by myself to run boost... so its not exactly uberdata but its working like it so it makes no difference.
092eg6
12-23-2009 01:38 PM
