Injector question...
Old Dec 18, 2004 | 09:58 PM
95excoupe's Avatar
Default Injector question...
If you add larger injectors to your car and dont tune it what happens? Does it run too rich, too lean, or just the same as it did only at a lower duty cycle?
Old Dec 18, 2004 | 10:02 PM
mrspeaker's Avatar
Default Re: Injector question... (95excoupe)
They wont add more fuel unless you change fuel maps or pressure..
Modified by Mrspeaker at 2:34 AM 12/19/2004
Old Dec 18, 2004 | 10:12 PM
omahaturbocivic's Avatar
Default Re: Injector question... (Mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">
They wont add more fuel unless you change fuel maps or pressure..</TD></TR></TABLE>
Well thats 100% wrong. If you dont change anything in the tuning then the duty cycle does not change and the car will run richer.
Old Dec 18, 2004 | 10:33 PM
mrspeaker's Avatar
Default Re: Injector question... (omahaturbocivic)
ok I dont know ****..
Old Dec 18, 2004 | 10:38 PM
T-RO's Avatar
^^^ lol
If you change the injectors but nothing else then they stay open the same amount of time as stock ones but are dumping more fuel.
Old Dec 19, 2004 | 07:26 PM
95excoupe's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">^^^ lol
If you change the injectors but nothing else then they stay open the same amount of time as stock ones but are dumping more fuel.</TD></TR></TABLE>
Okay yeah thats what I thought..hmm this might be a good thing I am pinging now with stock injectors when I really get on it. You think the 450's will richen them up too much? I am using the emanage that came with my greddy kit and I havent tuned it.
Old Dec 19, 2004 | 07:37 PM
CivicEJ1's Avatar
Default Re: (T-RO)
But remember this too..your injectors are spraying more gas with the bigger injectors and stock fuel pressure setting, but it'll be fine at idle, but when your rpm goes up the injectors will shot faster and that's where your problem will be. Because the pressure will drop since it's letting more gas out and at mid to high rpm you'll lean out and kaboom...
you have to increase the fuel pressure with a more lph fuel pump or get a fuel pressure regulator to increase the pressure...sure you'll be super super rich at low rpm but at mid to high rpm you'll be running okay rather than lean.
This only applies to untuned maps....for tuned maps they decrease the opening duration of the injectors at low rpm so you won't be runing too rich and fine tune the opening duration for mid to high rpm.
I hope this helped you understand more...
Old Dec 19, 2004 | 07:47 PM
95excoupe's Avatar
Default Re: (CivicEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
Makes sense...thanks for the info I am going to get them and wait till I can go get it tuned before I put them in. I also heard the dsm injectors arent as fast as the RC's in terms of how it sprays, I guess its a peak/hold vs saturated thing...regardless, I am still going dsm because I am a cheap *** and they are like $65. hahah
Old Dec 19, 2004 | 09:33 PM
T-RO's Avatar
let me know if you need a resistor box for your DSM injectors. I sell them
Old Dec 19, 2004 | 09:38 PM
CivicEJ1's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">let me know if you need a resistor box for your DSM injectors. I sell them </TD></TR></TABLE>
How much?
SkaiWu
Mar 14, 2008 03:27 AM
money moe
Jan 22, 2006 08:12 PM
EF_ST@TUS
Aug 12, 2005 07:03 AM
mamaboy
Feb 28, 2005 09:28 AM
oemDC2
Apr 7, 2004 08:23 PM
