Can spark plug gap cause a "misfire?"
12 Years Strong
Every since I boosted my car it has had a misfiring sound at idle. This did not happen when the car was on the motor. I installed a set of new plugs and gapped them at around .030. The car idles like it is misfiring, but drives perfectly while driving normal, and under boost.
I removed the plugs after about 200 miles, cleaned them and regapped them, and the idle was smooth?! Could spark plug gap cause the car to idle like crap?
12 Years Strong
Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">yes, but it sounds to me like you might be over fueling them at idle, what kind pf fuel management are you running</TD></TR></TABLE>
Warlbro 255, and a Vortec FMU - Only 7lbs until I can afford a standalone - I had Hondata but sold it when I parted out my last turbo kit
Re: Can spark plug gap cause a "misfire?" (HybridHatch88)
what temperature plug are u running. try gapping them a little closer. how do your ignition wires look? i had some magnecores and they were all beat up so i bought some brand new oem wires and that cured my missfire.
Re: Can spark plug gap cause a "misfire?" (donkiman)
You dont need to gap them smaller if it's happening during idle. Are you using stock injectors right now?
mpociask
12
05-25-2004 11:22 AM
