cleaning TIAL WG ? >>
Old Dec 16, 2004 | 06:27 AM
platinum00's Avatar
Default cleaning TIAL WG ? >>
do these ever need cleaned. if so what is the best method to do this.
what about the diaphragm, do they ever go bad and need replaced or cleaned.
platinum.
Old Dec 16, 2004 | 06:50 AM
yellowturbo's Avatar
if it work well I would not even touch it...
Old Dec 16, 2004 | 06:52 AM
b18bturbo's Avatar
Default Re: (yellowturbo)
the only thing you would have to look for is sticky valve. The valve if run on Race GAS can cause problems if you didnt get the option for the upgraded valve. Most units come with the Std valve. Just inspect and calen the valve thats the main thing. The actual diaphram doesnt usually fail but it can be peierced if trying to remove the spring incorrectly or incorrect installation
Old Dec 16, 2004 | 10:15 AM
platinum00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">if it work well I would not even touch it...
it seems to work fine. but i have never taken it over 10psi. i just want to be sure it's good to go before i turn it up..
platinum.
platinum00's Avatar
Default Re: (b18bturbo)
how do i check for a sticky valve. im assuming just move it and if it does not stick im good
platinum.
Old Dec 16, 2004 | 10:16 AM
Flamenco-T's Avatar
Default Re: (platinum00)
just check for carbon buildup. You can use WD40 to clean them up.
stan
Old Dec 16, 2004 | 11:12 AM
platinum00's Avatar
Default Re: (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">just check for carbon buildup. You can use WD40 to clean them up.
stan</TD></TR></TABLE>
thanks
platinum.
Flr Power
Nov 10, 2017 05:38 AM
Dunc
Oct 18, 2007 06:48 PM
Shift_Fast
Feb 19, 2005 11:24 AM
alpha
Mar 24, 2003 04:03 PM
IN VTEC
Sep 15, 2002 09:46 PM
