HX30 or HX35?
Old Dec 18, 2004 | 01:21 PM
drumking15's Avatar
Default Holset Turbos? HX30 or HX35 for gsr?
OK my setup for this turbo is gonna be:
ls/vtec setup
1834cc's
stock gsr head
gsr cams
9.2:1 CR
ge headstuds w/ vtec coversion kit
forged pistons (arias) & rods (eagles big bolts)
itr oil & h20 pumps
eq. length mani (toyosupra)
3" dp > ext cutout
a/w intercooled (custom made core)
wablro 255 hp
450 dsm injectors
uberdata tune
im looking for a quick spooling turbo for good street power...i want to get to 400whp w/ a relatively safe tune...and a 12 second integra
looking to run 7lbs at first then upgrade to 3bar map sensor and run 12 DD and around 16 @ the track
also most likely going to get 550's or bigger for 7psi +
any suggestions on the most suitable turbo or setup
Modified by drumking15 at 10:36 AM 12/19/2004
Old Dec 19, 2004 | 05:05 AM
drumking15's Avatar
anyone?
Old Dec 19, 2004 | 08:14 AM
powerofdreams8's Avatar
Default Re: (drumking15)
I haved a b16 and I LOVE my HX35. You will be fully spooled before 4500 w/ the HX35.
Old Dec 19, 2004 | 08:34 AM
Bailhatch's Avatar
Default Re: (powerofdreams8)
what exactly does "fully spooled" mean? 3.5 psi? 35 psi?
Old Dec 19, 2004 | 09:21 AM
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerofdreams8 &raquo;</TD></TR><TR><TD CLASS="quote">I haved a b16 and I LOVE my HX35. You will be fully spooled before 4500 w/ the HX35.</TD></TR></TABLE>
how much boost are you running?
and are where r u hitting full boost on your setup
Old Dec 19, 2004 | 12:10 PM
I have 8 psi on my stock b16 by just about 4800, and a few at 3000. Lots of advance before boost and a low vtec enagagement will really help out. Your bigger motor will have no problem spooling the HX35. Probably not the turbo for you if you want a smooth powerband though.
Old Dec 19, 2004 | 12:29 PM
drumking15's Avatar
powerband doesnt need to be all so smooth...prob gonna run slicks eventually on it...just looking to get a nice turbo for the street...quick spoolin and still have some room on the top end to make a decent 1/4mi car
Old Dec 19, 2004 | 01:30 PM
blundar's Avatar
then get a HY35. Your top end is going to be marginally (a few lbs/min) lower than the HX35, but it has a MUCH smaller hotside, and would spool a HELL of a lot sooner than a HX35, and with a properly designed manifold and wastegate setup, you might be able to build a system more efficent overall.
Old Dec 19, 2004 | 02:42 PM
Bailhatch's Avatar
Default Re: (blundar)
how does the HY35 compare to the HX30. is the hot side similarly sized?
Old Dec 19, 2004 | 05:57 PM
blundar's Avatar
HY35 = 9cm^2 housing (versus 12cm^2 for early HX35 + 15/16cm^2 for late HX35) which I believe works out to be slightly less than a .63 AR T3. Perfect for quick spooling if you ask me, and have a big enough wastegate to divert a lot of gas efficiently.
Old Dec 19, 2004 | 08:43 PM
drumking15's Avatar
no hy35...stupid outlet problem...and also they are just too small...prob good for a d-series...anything that small will spool a little tooo fast...hence why i think im set on the hx35...maybe uygrading to a bigger exh housing
Old Dec 20, 2004 | 06:39 AM
blundar's Avatar
my homie Speed Phreak runs a HX35 on his 2L sleeved 8.8:1 compression LS w/ cams. He has 13psi of boost by a little over 4 grand I believe. The HY will spool 35-40% faster than that. Think on it.
Old Dec 20, 2004 | 11:36 AM
drumking15's Avatar
id be more than content w/ a 4grand full spool...maybe a little higher when i step up to 16psi...but 4 grand is fine by me...any sooner and ill be having major traction problems
Old Dec 21, 2004 | 06:22 PM
drumking15's Avatar
anyone else runnin these snails?
Old Dec 21, 2004 | 06:52 PM
Joseph Davis's Avatar
HX30 is the equivalent of a .50 trim T3/04E that sucks for lower PR (poor efficiency at single digit boost). It will spool ~1000 rpms before the HX35, possibly quite similar to the HY35 which I've zero experience with.
2.0/VTEC + HX55 will spool. I haven't spoken with the gentleman who has this combo yet, so I have no details in re spool properties, but it's a built drag car over in europe.
Old Dec 21, 2004 | 06:57 PM
drumking15's Avatar
thanks for the input mr.davis...always glad to see you chime in...
ya im figuring 42-4300 full boost...w/ the 12cm housing
if i want more power..ill prob step up to the hx40 wheel which so conviently fits in the hx35 housing mauhaaa
Old Dec 28, 2004 | 12:06 PM
drumking15's Avatar
anyone runnin a hx40?
Old Dec 28, 2004 | 01:01 PM
O3DigitalBath's Avatar
hmm, I know a few people that will be very intrested in this thread...
anyone have maps for hx30? i've been looking for one but can't come up with one
Old Dec 28, 2004 | 02:19 PM
99_GS-T's Avatar
I would also be very interested in information on the Holset turbochargers. Are there any well trusted vendors that sell Holset products?
The holset site shows compressor flow ranges that reach pretty high on the pressure ratio axis, which is what I am interested in at 4500' above sea level. It would be much nicer to see a couple real compressor flow maps though.
Old Dec 28, 2004 | 07:35 PM
drumking15's Avatar
if anyone else drums up some info let'me know
Old Dec 28, 2004 | 09:09 PM
drumking15's Avatar
from huntin aroun on the dsm boards...seems the h40 runs about 70cfm vs the hx35's 60ish....very similar to that of a 60-1
Old Dec 29, 2004 | 04:51 AM
b18bturbo's Avatar
what holset information do you need i got access to the hx30-hx50 series turbos. I ran the hx30 on ls and it felt nice allround turbo. I then sold that to j davis on here now he has it. the hx35 is also a nice setup it flows very well with its exhaust housing. Most mustang guys use the hx35 in ranges of power from 450-500hp on single turbo on stock 302. some guys have used the hx40 but mostly on diesel and high boost applications. They make hx35/40 combo if you can find them mostly aftermarket.
Old Dec 29, 2004 | 05:19 AM
drumking15's Avatar
can you email me the compressor maps and any info you have on those bad boys
drumking15@yahoo.com
thanks
Old Dec 29, 2004 | 05:24 AM
b18bturbo's Avatar
tbhey are very large pdf files i can host them on my webserver in a directory let me upload them
Old Dec 29, 2004 | 05:46 AM
b18bturbo's Avatar
Default Re: Holset Turbos? HX30 or HX35 for gsr? (drumking15)
this is all the information i have so far gathered through the year I hd the compelte hx30 catalog at one time but i dont know what happend to it
http://www.sthperformance.com/turbo/
