Turbo engine break in
Old Dec 16, 2004 | 12:03 PM
JoeD427's Avatar
Default Turbo engine break in
If i get a motor built fresh and plan to turbo it, should I put it in the car and break it in without the turbo installed, or drop everything in together and then break it in?
Old Dec 16, 2004 | 12:18 PM
tgreaves's Avatar
Default Re: Turbo engine break in (JoeD427)
Im going to break my motor in without the turbo on it and install it after my engine and clutch are broke in all the way..
Old Dec 16, 2004 | 12:23 PM
boostjunkie757's Avatar
hahaha...
my roommates comment was "break in??? wtf??? boost the **** out of that bitch..."
Old Dec 16, 2004 | 12:24 PM
turboEGhatch's Avatar
Default Re: (boostjunkie757)
Dumped my entire new motor in the car and broke it in on the dyno last saturday
Old Dec 16, 2004 | 12:29 PM
turbosi03's Avatar
Default Re: (turboEGsedan)
here's how I'm gonna do it...
https://honda-tech.com/zerothread?id=878397
Old Dec 16, 2004 | 12:40 PM
JoeD427's Avatar
Default Re: (turbosi03)
looks good, sounds like earl knows his stuff.
Old Dec 16, 2004 | 12:45 PM
dennis's Avatar
what I did was break it in naturally aspirated. My reasoning was that this was a freshly built engine and if I'm going to run into any problems, I want it to be as simple as possible to troubleshoot.
This helped out greatly when I ran into an oil consumption issue. It all turned out to be that my rings on #1 were inline, but the bottom line was there were fewer factors to investigate.
Old Dec 16, 2004 | 12:47 PM
JoeD427's Avatar
Default Re: Turbo engine break in (dennis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennis &raquo;</TD></TR><TR><TD CLASS="quote">what I did was break it in naturally aspirated. My reasoning was that this was a freshly built engine and if I'm going to run into any problems, I want it to be as simple as possible to troubleshoot.
This helped out greatly when I ran into an oil consumption issue. It all turned out to be that my rings on #1 were inline, but the bottom line was there were fewer factors to investigate.</TD></TR></TABLE>
what do you mean that your rings were in line?
Old Dec 16, 2004 | 01:00 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoeD427 &raquo;</TD></TR><TR><TD CLASS="quote">
what do you mean that your rings were in line?</TD></TR></TABLE>
All the compression rings and/or oil rings were lined up so oil/compression could travel past the piston..
Old Dec 16, 2004 | 01:12 PM
JoeD427's Avatar
Default Re: Turbo engine break in (tgreaves)
gotcha thanx
Old Dec 17, 2004 | 12:21 PM
JoeD427's Avatar
any more advice guys?
Old Dec 17, 2004 | 05:08 PM
PrettyLude's Avatar
follow earl's method
skillzhb
Jan 16, 2009 08:06 AM
ITSTOCK
Apr 6, 2004 05:33 AM
Briman2021
Oct 28, 2003 08:34 AM
Driven
Jun 15, 2003 02:09 PM
Integra187
Sep 28, 2001 02:48 PM
