Hard lines for Oil Feed???
Old Dec 19, 2004 | 05:22 AM
wantboost's Avatar
Who is Mr Robot?
Default Hard lines for Oil Feed???
I know that some people have used hard lines for coolant to turbos, but what about using hard lines for oil? Something similar to the stainless lines used for direct port nitrous systems? Obviously it would be for the oil feed. Any ideas on if this would work, along with line inner diameter? Would i be better of using braided lines the whole way?
Old Dec 19, 2004 | 06:24 AM
Johnyquest's Avatar
Default Re: Hard lines for Oil Feed??? (wantboost)
There's no reason it wouldn't work, but using a braided line is just easy -- so, take your pick. I used a -3an brake line that was the perfect lenght. I got it online somewhere for 20$ shipped -- just search around for -3an lines. Then use a brass tee and nipple. Setup done for under $30.
Matt
Old Dec 19, 2004 | 06:43 AM
Turbo23lx's Avatar
Earls sells 3 an line already with the fittings on them ready to install.
Old Dec 19, 2004 | 07:18 AM
Bailhatch's Avatar
Default Re: Hard lines for Oil Feed??? (Turbo23lx)
I have seen it done with hard (brake) lines. 3/16" is a good size. Sucks to work on a setup like this though because you either have to bend the line or remove the whole thing to get at the turbo.
Old Dec 19, 2004 | 08:26 AM
T-RO's Avatar
My oil feed is a "brake line". It works fine and cost like $4. lol
I'm going to upgrade to SS lines though just because.
Old Dec 19, 2004 | 08:51 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (T-RO)
yea, since we build racebikes, i have an ample supply of stainless braided line, the only problem is the fittings are designed for banjo bolts. The orifice in the bolt is designed for pressure, not flow. so i dont think that would work, any ideas?
Old Dec 19, 2004 | 09:18 AM
diputs's Avatar
Default Re: (wantboost)
how small is the orifice? In some cases, restricting flow at the turbo is beneficial...(oil restrictors)...it might not be a bad setup. I'm using a banjo bolt on my feed line. But, it's the big banjo union that comes with the greddy kit.
Old Dec 19, 2004 | 09:20 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (diputs)
i don't have the bolt in front of me, but it's alot smaller than the tial banjo. In the next few days i should have a size for you guys
Nermin
Oct 10, 2010 08:30 PM
shrug
Nov 4, 2004 06:21 PM
Del_Slowest
Oct 22, 2003 03:48 AM
dumbkid
Feb 18, 2003 03:48 PM
johnisenglish
Oct 30, 2002 05:19 PM
