whats the diff in 50 mm performance???
Old Dec 15, 2004 | 04:55 PM
KiNG $h!t's Avatar
Default whats the diff in 50 mm performance???
okay im wondering what is the difference in using a 50mm tial BOV vs. a smaller bov such as a greddy type s or some where around those lines?
Old Dec 15, 2004 | 05:30 PM
KiNG $h!t's Avatar
bump.
Old Dec 15, 2004 | 06:31 PM
b16sedan's Avatar
Default Re: whats the diff in 50 mm performance??? (this guy 2fast)
When you're pushing a lot more boost or if you're on a larger motor the smaller BOV's will hit a point where they simply can not flow any more air, and will cause compressor surge. A larger and better flowing BOV like the Tial will eventually reach this point too, but you will have to push a lot more boost/airflow through it.
Old Dec 15, 2004 | 07:14 PM
kabaroo's Avatar
Default Re: whats the diff in 50 mm performance??? (b16coupe)
^^ thats when you get 2!
Old Dec 16, 2004 | 06:31 AM
KiNG $h!t's Avatar
what if you are pushing a minimum amount of boost will it affect it still
Old Dec 16, 2004 | 09:04 AM
b16sedan's Avatar
Default Re: (this guy 2fast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by this guy 2fast &raquo;</TD></TR><TR><TD CLASS="quote">what if you are pushing a minimum amount of boost will it affect it still </TD></TR></TABLE>
? Think of the BOV in the same context as an exhaust system. A Larger exhaust will support a higher level of horsepower than a smaller exhaust, but the large exhaust will still do perfectly fine at lower boost and horsepower levels. Same thing with a BOV. Larger means it can handle more boost and airflow, but it will still do fine on a stock motor setup. I have a Tial BOV on my setup and I was running a stock block LS/VTEC at 7-8 psi for a while.
Old Dec 16, 2004 | 09:45 AM
KiNG $h!t's Avatar
ok cuz i fo0und a decent deal on a tial 50mm wastegate but didnt want to buy it if it was going to hurt my performace.
97dc2
Jun 7, 2005 02:22 PM
Bizarre
May 27, 2005 08:01 PM
b16sellout
Mar 31, 2005 06:07 PM
dmecarboy
Jul 10, 2003 01:50 PM
TeGsr94
May 23, 2002 07:49 PM
