38mm or 44mm BOV?
38mm or 44mm wastegate?
Other than the cost of the wastegate is there any benefit/problem going with a 38mm or 44mm wastegate? Does the wastegate need to match the HP of your setup or could I go with a larger one if I wanted to? I'm worried the larger wastegate may not work as well if I'm not pushing the HP rated for the 44mm. Thanks!
Modified by otto at 9:32 PM 12/17/2004
Modified by otto at 9:40 PM 12/17/2004
Quad-Damag
01-13-2005 03:12 AM
Peter K
06-12-2003 07:22 AM
