what is the potental of a LS
Old Dec 16, 2004 | 01:45 PM
BrooksGSR's Avatar
Default what is the potental of a LS
i want 400+ wheel, i have a 94 gsr but dont want to mess with it i just want to drive it. I can get a mint 91 teg for 1,000, it's mint in every way. I just dont want to mess with both cars i was thinking of swaping motors between the two bc im not sure if the LS can make the Power i want. If i were to do the LS it would see cams springs internals... all the goodies and possibly a sc61, i just wanted to find oput what the LS is good too, thanks.
PS. and what cams would u recomend with the LS and springs, i would do cp's (thinking9:1)and eagle rods for the bottom.
Modified by BrooksGSR at 3:00 PM 12/16/2004
Modified by BrooksGSR at 3:01 PM 12/16/2004
Old Dec 16, 2004 | 01:46 PM
RyanEJ8's Avatar
Default Re: what is the potental of a LS (BrooksGSR)
You could easily make 400+whp with a built LS.
Old Dec 16, 2004 | 01:49 PM
PureTeg420's Avatar
Default Re: what is the potental of a LS (RyanCivic2000)
I made 427whp off of a stock LS head and a .54 trim t3/t04e. The bottom end is built, but the head is completely stock and restrictive as hell.
Old Dec 16, 2004 | 03:24 PM
Ben Huynh's Avatar
Default Re: what is the potental of a LS (PureTeg420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PureTeg420 &raquo;</TD></TR><TR><TD CLASS="quote">I made 427whp off of a stock LS head and a .54 trim t3/t04e. The bottom end is built, but the head is completely stock and restrictive as hell.</TD></TR></TABLE>
I totally agree about the head. You get plenty of torque with the LS motor but top end power is lacking.
Old Dec 16, 2004 | 03:55 PM
Trance minister's Avatar
Wow, those are great numbers. Aftermarket sleeves too? I like seeing straight LS motors putting that kind of power down. I'm in the process of building an LS for good numbers as well.
Old Dec 16, 2004 | 04:03 PM
1.8's Avatar
1.8
Default Re: what is the potental of a LS (Trance minister)
what are the stock LS making?
Old Dec 16, 2004 | 04:05 PM
RidinStock's Avatar
Default Re: what is the potental of a LS (1.8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">what are the stock LS making?</TD></TR></TABLE>
90-91 b18a = 130hp
92-93 b18a = 140hp
94+ = 142hp (I think)
Old Dec 16, 2004 | 04:08 PM
Ben Huynh's Avatar
Default Re: what is the potental of a LS (RidinStock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinStock &raquo;</TD></TR><TR><TD CLASS="quote">
90-91 b18a = 130hp
92-93 b18a = 140hp
94+ = 142hp (I think)</TD></TR></TABLE>
Yep that's correct.
Old Dec 16, 2004 | 04:16 PM
Joseph Davis's Avatar
Default Re: what is the potental of a LS (ben@importparts.com)
The head isn't as restrictive as the stock camshafts - the true problem. A gander at StyleTeg's NA LS build - and the ITR that dynoed immediately after his car - shows you what a stock LS head with a good set of cams can do.
High rpms get strangled by smallish intake valve and port design. P8R (some JDM CRV) headcasting has 33mm intake valves which help with top end flow.
400 whp will be hard on pump gas, I wouldn't feel safe past 350 even with a good intake/turbo manifold that helps reduce pumping losses. With a P8R head combo it might be doable, due to more topend flow, just like the VTEC heads allow. Running inexpensive 100LL from the airport, or 93 octane "sweetened" with 100LL, would allow it no problem.
Speed PHreak would be a good person to generally harass on the subject - built bottom end, stock head with a set of cams, eats crotch rockets. I believe dear sweet Ben sold him the one Eagle rod he needed after his spun bearing last year - some ppl were being dicks about selling one single rod, you know
Food for thought.
Old Dec 16, 2004 | 04:17 PM
PureTeg420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com &raquo;</TD></TR><TR><TD CLASS="quote">
I totally agree about the head. You get plenty of torque with the LS motor but top end power is lacking.</TD></TR></TABLE>
You said it, 386ft/lb is nice for getting the car moving, but it begins to die off bad after 7k rpm. I've got a s2 intake manifold port matched it to the head, but clearly the head is reaching it's limits
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trance Minister &raquo;</TD></TR><TR><TD CLASS="quote">
Wow, those are great numbers. Aftermarket sleeves too? I like seeing straight LS motors putting that kind of power down. I'm in the process of building an LS for good numbers as well. </TD></TR></TABLE>
Yes, GE sleeves. It's been tough to stay away from an ls/vtec, but the car has amazing street drivability. Of course 84.5mm, a restrictive head, and a ball bearing turbo help that a bit.
Old Dec 16, 2004 | 04:27 PM
Ben Huynh's Avatar
Default Re: what is the potental of a LS (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">
Food for thought.</TD></TR></TABLE>
That's something I didn't get at all. It took all of 3 days to get the single rod. I guess we're in the business of helping our customers while others are out there just want to make easy sales and quick cash.
Old Dec 16, 2004 | 04:31 PM
mdpalmer's Avatar
Yes, GE sleeves. It's been tough to stay away from an ls/vtec, but the car has amazing street drivability. Of course 84.5mm, a restrictive head, and a ball bearing turbo help that a bit.</TD></TR></TABLE>
The torque you stated--386 ft-lb--is for your car? If so, do you have a picture of the dyno chart? The turbo LSs that I've seen (at least on the internet, various turbos/manis/etc.) appear to have a torque drop quite a bit earlier, starting somewhere north of 5000 RPM.
Old Dec 16, 2004 | 04:37 PM
1.8's Avatar
1.8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinStock &raquo;</TD></TR><TR><TD CLASS="quote">90-91 b18a = 130hp
92-93 b18a = 140hp
i meant with turbo. just wanna see what numbers are out there.
Old Dec 16, 2004 | 04:39 PM
Ben Huynh's Avatar
My LS from 7 years ago made 255whp and 211lb/ft at 10psi. Stock LS, stock DRAG kit.
Old Dec 16, 2004 | 04:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com &raquo;</TD></TR><TR><TD CLASS="quote">That's something I didn't get at all. It took all of 3 days to get the single rod. I guess we're in the business of helping our customers while others are out there just want to make easy sales and quick cash.</TD></TR></TABLE>
He certainly appreciated it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mdpalmer &raquo;</TD></TR><TR><TD CLASS="quote">The turbo LSs that I've seen (at least on the internet, various turbos/manis/etc.) appear to have a torque drop quite a bit earlier, starting somewhere north of 5000 RPM.</TD></TR></TABLE>
If Speedy wouldn't be an asshat about his top secret dyno sheet, you'd see peak torque at 6300 rpm, with no noticeable tapering until ~7200 rpm, and that's attributable to the dyno operator lifting at 7400 when he was specifically instructed to take her to 8K. Boost was steady, crept at most 1 psi from 4.5K to 7400, so it's not a boost creep erroneous reading.
Old Dec 16, 2004 | 04:46 PM
mdpalmer's Avatar
i meant with turbo. just wanna see what numbers are out there.</TD></TR></TABLE>
Track times on one guy's car: https://honda-tech.com/zerothread?id=1070862
A dyno chart: https://honda-tech.com/zerothread?id=1033424
Another guy's car: https://honda-tech.com/zerothread?id=718123
EDIT: These are *stock* engines, BTW
There's a lot more in the archives.
Old Dec 16, 2004 | 04:48 PM
Ben Huynh's Avatar
We appreciate you guys in NC.
Old Dec 16, 2004 | 05:14 PM
PureTeg420's Avatar
Default Re: what is the potental of a LS (mdpalmer)
The torque you stated--386 ft-lb--is for your car? If so, do you have a picture of the dyno chart? The turbo LSs that I've seen (at least on the internet, various turbos/manis/etc.) appear to have a torque drop quite a bit earlier, starting somewhere north of 5000 RPM.</TD></TR></TABLE>
The torque begins to fall around 5000, but it's not as drastic until about 6700. Technically, I did clean up the exhaust ports a little bit, nothing drastic however. I seriously doubt it helped much. I am sorry I don't have a dyno graph. It was supposed to be emailed to me, but I have yet to recieve it in 4 months
Old Dec 16, 2004 | 05:28 PM
alpha's Avatar
What octane gas was this with?
Old Dec 16, 2004 | 05:30 PM
PureTeg420's Avatar
Default Re: what is the potental of a LS (0x64)
110. I made somewhere around 370whp on 92...
Old Dec 16, 2004 | 07:00 PM
Mr.DC2TurBo's Avatar
Your in luck.. This setup will ezly get u into the 400hp.
LS PnP head - $400 + shipping: This will let you rev up to 9K rpm
DH Race Port and Polish
Dual Valve Springs (NOT STOCK)
Titanium Retainers
Dh-Racing Valves
3 Angle Valve Job
Diamond Milling/Resurfacing
Glass Beaded Combustion Chambers
Glass Beaded Head (Entire Head)
Line Honed Cam Journals
Hot Tanking/Degreasing
Crower 402T * NEW * - 400 plus shipping
Willing to sell them for 700 plus shipping if u get both
Old Dec 16, 2004 | 07:01 PM
Default Re: what is the potental of a LS (Mr.DC2TurBo)
This same head made 300hp on an LS at 8 psi *SERIOUS POWER*
Old Dec 16, 2004 | 07:03 PM
Puurdy!
Old Dec 16, 2004 | 07:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trance minister &raquo;</TD></TR><TR><TD CLASS="quote">Puurdy!</TD></TR></TABLE>
Old Dec 16, 2004 | 07:24 PM
untitled's Avatar
what about:
t3/t04e .48 turbine .63 57 trim compressor
Ramhorn = length
3inch straight pipe (race car)
JRC FMIC
@13psi
What would this do on a stock, fresh engine tuned with Uberdata?
I was thinking 300whp range?
