Compression on a LS/Vtec
Old Dec 17, 2004 | 07:24 AM
dwn4cause's Avatar
Default Compression on a LS/Vtec
I did a compression test and got 150,145,145,150.. this is on a b18B1 block with a B16a2 head.. what do you guys think?
Old Dec 17, 2004 | 07:36 AM
turboEGhatch's Avatar
Default Re: Compression on a LS/Vtec (dwn4cause)
You cannot compare compression numbers with any amount of accuracy. The elvation you're at, barometric pressure, temperature, how long you crank the motor for, etc, can all have a huge effect on what your compression tester reads. As long as all the numbers are within 5-10% you're gravy.
Old Dec 17, 2004 | 08:25 AM
Kowalski's Avatar
Was this at normal Operating temperature?
They seem close, but a little low...
Old Dec 22, 2004 | 07:53 AM
dwn4cause's Avatar
Default Re: Compression on a LS/Vtec (Kowalski)
yep done at operating temp
Old Dec 22, 2004 | 07:58 AM
b18bturbo's Avatar
as logn as it even across th cylinders you should be happy. there is alot variances that can cause low number such as guage and air elevation etc. but with those numbers across the board looks okay
zCivic
Apr 28, 2007 01:17 PM
K20 EG
Jun 17, 2003 11:26 AM
CNSK
May 24, 2003 03:26 PM
98 Ek LsVtec
Feb 7, 2002 09:25 PM
