Turbo for 2000 civic
Old Dec 16, 2004 | 02:15 PM
danman3323's Avatar
Default Turbo for 2000 civic
I have a 2000 civic SI and I want to put turbo in it, but I was wondering what I should do to the engine first so that the engine will handle the trubo kit. Should I get cam gears and stuff?
Old Dec 16, 2004 | 02:17 PM
31flavorscivic's Avatar
Default Re: Turbo for 2000 civic (danman3323)
Your engine should be able to safely handle 6-7 PSI on stock internals. Just my .02.
Old Dec 16, 2004 | 02:37 PM
Rod.'s Avatar
Default Re: Turbo for 2000 civic (31flavorscivic)
Your engine can handle a turbo on stock internals. Get it tuned also
Old Dec 16, 2004 | 02:40 PM
b1ackc1v1c's Avatar
Do a compression test...also read this https://honda-tech.com/zerothread?id=1024174
Old Dec 16, 2004 | 03:19 PM
donkiman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danman3323 &raquo;</TD></TR><TR><TD CLASS="quote"> Should I get cam gears and stuff?</TD></TR></TABLE>
hmmm. you already have cam gears. why do u want new ones?
Old Dec 16, 2004 | 04:42 PM
Default Re: Turbo for 2000 civic (donkiman)
I heard from someone on this site that doing improved cams, lifters,and headwork like that on a turbo car is not the correct avenue for performance. I would have to search hard for the thread, but someone correct me if I'm wrong.
Old Dec 16, 2004 | 04:49 PM
donkiman's Avatar
correct. stock honda cams are fine. if you want to run your stock block just get decent size turbo and tune it. if you wanna run past 300whp its recomded you upgrade pistons, rods, rings, and possibly valve springs for higher reving. if you want to go to the limit that you can get sleeves but generally for street use thats not really required.
Old Dec 17, 2004 | 06:55 AM
danman3323's Avatar
Can I just take it to any shop to get it tuned, or a specific shop? So I should tune it before I put on the turbo kit, Right?
Old Dec 17, 2004 | 05:18 PM
PrettyLude's Avatar
you tune it after you put the kit on
Skulleds
Oct 31, 2014 06:15 AM
StreetRac3r
Jun 7, 2007 09:12 AM
mrbsponge
May 30, 2004 06:15 PM
Rhythm Racer
Jul 16, 2003 08:14 AM
TurboSohc
Apr 20, 2002 09:00 AM
