New Sleeved block... its rusting!!!!!
Old Dec 17, 2004 | 09:02 AM
pubestripe's Avatar
Default New Sleeved block... its rusting!!!!!
ok i have a b16 block that i bought that was sleeved... ive had it in my closet for a couple months, and now it is beginning to rust... what do i need to put on it to make it stop??? it has some sort of oil or grease on it when i got it, but now that is worn off!!!! please help me!!!!
Old Dec 17, 2004 | 09:06 AM
Tchleung's Avatar
how bad is the rust? will it coem off if you light wipe it down with something or is it really on there now and pitting? cover the cylinder walls with assembly lube.
Old Dec 17, 2004 | 09:29 AM
BoostedEG6's Avatar
Default Re: New Sleeved block... its rusting!!!!! (pubestripe)
you should take a rag and wipe all the cylinder walls with oil then take and wrap it up in garbage bags to keep it as dry as possible
Old Dec 17, 2004 | 09:37 AM
Adi Radoncic's Avatar
On Fire!
Just spray some WD-40 on the cylinder walls and the top, clean off the surface rust with a rag, than spray WD-40 again on all parts of the sleeves and you're ready to store that baby for a long time..
Old Dec 17, 2004 | 09:42 AM
TheShodan's Avatar
Moderator
Default Re: New Sleeved block... its rusting!!!!! (newgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr &raquo;</TD></TR><TR><TD CLASS="quote">Just spray some WD-40 on the cylinder walls and the top, clean off the surface rust with a rag, than spray WD-40 again on all parts of the sleeves and you're ready to store that baby for a long time..</TD></TR></TABLE>
Exactly. You want the block covered so that the sleeve can stay smooth and moist. remember, the sleeves are of a ductile iron that oxidizes easily.
Old Dec 17, 2004 | 03:14 PM
pubestripe's Avatar
Default Re: New Sleeved block... its rusting!!!!! (TheShodan)
u sure that wd40 would work? it is a hydrocarbon and i usually dont recommend that to customers, seeing as how i work at a hardware store and i am there now... thanks for the replies!
Old Dec 17, 2004 | 03:28 PM
ladysman's Avatar
WD40 is what I used to store mine. It works fine so don't get your panties in a bunch. Just go to walmart, buy a can or two along with a 30 pack of beer.
2 birds with 1 stone killed.
Old Dec 17, 2004 | 03:32 PM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pubestripe &raquo;</TD></TR><TR><TD CLASS="quote">u sure that wd40 would work? it is a hydrocarbon and i usually dont recommend that to customers, seeing as how i work at a hardware store and i am there now... thanks for the replies! </TD></TR></TABLE>
You are right but I have never seen any problems arise from using WD-40 on the cylinder walls. I use Royal Purple assembly lube.
Old Dec 17, 2004 | 05:00 PM
PrettyLude's Avatar
any assembly lube would work
Old Dec 17, 2004 | 05:25 PM
maddog20's Avatar
Default Re: (PrettyLude)
you can use cooking oil also!
Old Dec 17, 2004 | 10:30 PM
pubestripe's Avatar
Default Re: (maddog20)
ok so i used some wd40 to clean the rust off, then i soaked the sleeves in oil, wrapped the whole block in a plastic bag, and put it away!!!! that should do it...lol, thanks again for the replies!
Old Dec 17, 2004 | 10:48 PM
Tchleung's Avatar
wrap it in saran wrap. air tight..
black0hatch
Jun 5, 2008 09:54 PM
battlecrxT
Sep 14, 2007 10:33 AM
290allen
10
Aug 1, 2006 11:08 PM
angry_LS
Jan 27, 2005 08:32 AM
baphomet
Dec 8, 2003 02:00 PM
