Need help fast 8:5:1 Vs 9:3:1 HELP ME DESIDE!
Im posting here, due to no responce in the intgra forum for over an hour, and i really need to know.
Ok I go to order the 9:3:1 Pistons for my turbo build, and I get a message from the guy im buying them from.
Hes trying to tell me To get the 8:5:1 for boost. He was telling me if im running over 12 psi on a 9:3:1 setup ill need race gas, and with the 8:5:1 I wont, and this will be better for makeing over 350+ hp.
I had the 9:3:1 planned for a while, I now all the sudden im brought up with a question.
Is the 8:5:1 all that different? I dont want to have to run a ton of boost to make up for that power drop
So 9:3:1 OR 8:5:1 And give your reasons why or why not
Re: Need help fast 8:5:1 Vs 9:3:1 HELP ME DESIDE! (vtecluder97)
You don't need race gas to run 12 spi on 9.3:1. I plan running about 15 psi at 10:1 with 93 octane pump gas.
Go with the 9.3:1 pistons.
Re: Need help fast 8:5:1 Vs 9:3:1 HELP ME DESIDE! (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">9.3:1</TD></TR></TABLE>
on 9:3:1 Compression with these mods: What do you think Ill be good for?
Pressed, Welded block guard(will not move)
Block decked
Stock reworked head
Eagle Rods
SRP 9:3:1 Pistons
How much can I push on these rods pistons at the 9:3:1 compression
Block decked
Stock reworked head
Eagle Rods
SRP 9:3:1 Pistons
Your setup could easily be good for 400whp, depends on what turbo you run. There is no need to weld a blockguard a place.
