would this work?
Old Dec 16, 2004 | 10:03 AM
desert eagle's Avatar
Default would this work?
ok i've noticed that alota katz in arizona runs vafc, 440s, with a fmu. running pig rich but making decent numbers. im running vafc, 440s no fmu. i set my setting to the recommend -35 hi & lo nar and -35 lo -39 - 34 hi wide. my car really doesn't like those setting and shows no signs of detnation. my timing is 1 degree retard. fpr at 55 or so wot.
i have a 3bar map because i wanna boost 12-15lbs. would a boosted program like uberdata or something work as a baseline and fine tuned with a vafc? just something hella driveable for the time being until febuary.
thanks
Old Dec 16, 2004 | 12:12 PM
Default Re: would this work? (LsVteC81)
bump for some advise
Old Dec 16, 2004 | 12:19 PM
96-EJ6 B18C's Avatar
Uberdata is good stuff. stay the hell away form an FMU (Fucks Motors Up). Check out this link
http://www.pcimulti.org/uberdata
read up!
EDIT: fixed link
Modified by 96-EJ6 B18C at 9:26 PM 12/16/2004
Old Dec 17, 2004 | 03:15 PM
Default Re: would this work? (96-EJ6 B18C)
thanks but i don't have the equipment to use uberdata.
Old Dec 17, 2004 | 03:51 PM
dan_w_82's Avatar
Just a thought what is need ed with a stand alone? Laptop?
If so what program would the laptop have to have? I have a old one that I would never use for anything but this so I thought I'd ask because I need info on management also.
Old Dec 21, 2004 | 07:23 PM
dan_w_82's Avatar
bump for what is needed for a stand-alone?
Old Dec 21, 2004 | 07:58 PM
Default Re: (dan_w_82)
It depends on which one you go with, and wether you will be doing the tuning yourself or having a shop do it for you. Some systems require a custom wiring harness and some are "plug n play" but all of them will need to be tuned. If your going to do the tuning yourself you'll need a laptop, if not then don't worry about it.
As far as not having the right equipment to use Uberdata you probably have most of what you need already, the Uberdata program (download from the uberdata site above for free), some simple supplies to chip your ECU (do a search for Keebler65 he has an excellent writeup on chipping), and a ROM burner http://www.moates.net
Also, if your planning on doing your own tuning, you'll need a wideband O2.
Old Dec 21, 2004 | 08:17 PM
dan_w_82's Avatar
Default Re: (96-EJ6 B18C)
Ok so if I get uberdata then I can tune myself from programs on uberdata? I have a laptop but it's a older one, what kind of memory and computer options on the laptop are required? Do you think it is a pretty easy process to do for the do-it-yourself types if all the info on how to tune is available? Sorry just a few ?'s I'm curious about. Noone around here has any stand-alone so I'll be the first. I'm interested but I just thought it had to be taken to the shop to get tuned. I'll check out the info you have for me thanks
Throwdown
Jun 22, 2006 05:55 PM
MickeeFREE
Apr 14, 2005 09:36 PM
808b18c1boosted
Dec 23, 2003 01:10 PM
leadtrum
Dec 21, 2002 08:12 PM
Turbo_Si
Aug 13, 2002 09:17 AM
