JRSC setup
Old Dec 15, 2004 | 12:30 PM
93supercoupe's Avatar
Default JRSC setup
I got some questions regarding my JRSC setup, heres the parts i have
LS/vtec, gsr head
forged pistons, GSR comp.
CTR cams
DC header
One question is what size throttle body should i use, eventually i want to run 12pounds, also will an AFC with 440's be sufficient for this if i use a boost retarding ignition?
Thanks in advance
Old Dec 15, 2004 | 01:53 PM
cnydc2's Avatar
Default Re: JRSC setup (93supercoupe)
The GS-R throttle body should work just fine. The S-AFC can support 550cc injectors and that should be more than enough for 12psi. If you opt to use the S-AFC I've got one that was installed but never tuned and i am getting rid of it for a stand-alone unit, let me know if you are interested.
Old Dec 21, 2004 | 09:47 AM
DC2Slow's Avatar
use hondata
Old Dec 21, 2004 | 11:19 AM
turbodav's Avatar
Default Re: JRSC setup (DC2Slow)
I have a similar set up and im using a 64mm throttle body, 440cc injectors and hondata 11psi.
Old Dec 21, 2004 | 11:41 AM
hypa's Avatar
Default Re: JRSC setup (turbodav)
When you up the TB size on a supercharged car, you'll see some real positive results. Most blower tuners will agree that tha biggest TB you go that will still allow for a good idle and throttle response is the best bet.
FYI, Richard Holdener found a 10whp gain going from a 60mm tb to a 65mm unit on a SOHC jrsc powered car. More recently, I found some really nice gains going from a stock GSR tb, to a tapered GSR tb.
Old Dec 21, 2004 | 12:50 PM
prestonpark's Avatar
Default Re: JRSC setup (hypa)
dam i have a ported throttle from maxbore never put it on never thoguht it will do anything ill keep u guys posted when i put this throttle body on
Old Dec 21, 2004 | 02:00 PM
Default Re: JRSC setup (civic2003)
is 70 too big on a b series?
C_Rock77
Apr 1, 2009 05:18 AM
done
Aug 4, 2006 11:23 PM
redmethods
Jan 29, 2004 04:20 AM
morepoop4u
Sep 7, 2003 10:01 PM
B18Flip
Sep 16, 2002 03:02 PM
