mild ls block build?
Old Dec 15, 2004 | 02:21 PM
pvt_awol's Avatar
Default mild ls block build?
Noob here <------ hahaha... can't find what I need in the search, so I'll ask it.
I eventually would like to send my LS block off to AEBS to have it sleeved and decked. I got a quote from my shop (and AEBS) for about 3g's, and that will include the rods and pistons etc. to run upwards of 30 psi.
Well, I got to thinking, I'm not gonna build a race car here. So what if I just threw some good rods, low comp. pistons, and maybe a block guard in there, and turned the boost up to like 15 psi? My shop guy was like.... well, just get the AEBS stuff.
So guys, my question:
What is your all experience with reliability on an LS block with good rods (eagle etc.) and some 8.5:1 or so JE pistons (etc.) with like a NuFormz block guard and around 15 psi? Pretty good for a daily driver? I know this should be good for about 300 hp. Like I said, I don't need a 500 hp race car, so AEBS may be overkill. But I would like a faster daily driver. Hit me up with some opinions.
Old Dec 15, 2004 | 03:01 PM
Blackack26's Avatar
Default Re: mild ls block build? (pvt_awol)
The upper limits of the stock block is roughly 300whp, and that's with a bone stock block. Most will say the stock sleeves are good up to 400-450whp.
Depending on where you want to go with the car, if it will just be your daily diver on 15psi, you will be fine with some forged internals.
EDIT: you can't find what you need in the search?? mans theres so much info on this subject I could read non-stop for days
Old Dec 15, 2004 | 03:33 PM
blown_LS's Avatar
Default Re: mild ls block build? (Blackack26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 &raquo;</TD></TR><TR><TD CLASS="quote">The upper limits of the stock block is roughly 300whp, and that's with a bone stock block. Most will say the stock sleeves are good up to 400-450whp.
EDIT: you can't find what you need in the search?? mans theres so much info on this subject I could read non-stop for days</TD></TR></TABLE>
This pretty much sums it up for you. I mean i put together turbo kit for my teg without posting a single post. Hit the search and you will find tons of usefull information on the subject. Happy boostin'
Old Dec 15, 2004 | 03:40 PM
pvt_awol's Avatar
Default Re: mild ls block build? (blown_LS)
I just couldn't quite nail down what I needed with the search. I was kinda expecting someone to pop up and say, hey dood, I only spend a grand for forged stuff, it's waaaay cheaper... or hey man, get the AEBS, cause you'll spend the money anyway. But I'm satisfied with what you guys have provided. Thank you.
PR8urVtec
Engine Machining & Assembly
21
Dec 14, 2016 04:51 PM
thugsbryan
Mar 27, 2015 09:48 AM
AViciousTHRUST
May 20, 2006 03:06 PM
eag36
Aug 13, 2005 10:22 PM
