Switching to Uber - JRSC MAP question
Old Dec 15, 2004 | 05:22 PM
JRciv's Avatar
Default Switching to Uber - JRSC MAP question
Since I'm making the switch, I'm selling my JR stuff. When I sell the MAP controller, should I keep the adaptor that feeds boost to the sensor, or should I go back to the stock configuration?
Old Dec 15, 2004 | 05:37 PM
folicor's Avatar
Default Re: Switching to Uber - JRSC MAP question (JRciv)
keep your map sensor reading from the manifold, not the throttle body. I had an SMC and swithced to UBER, best money I've ever spent.
Old Dec 15, 2004 | 07:35 PM
Muckman's Avatar
Moderator in Chief
It needs to measure pressure after the blower otherwise it wont see boost.
Old Dec 15, 2004 | 08:33 PM
Sonny's Avatar
That little adapter that JR makes for the MAP controller is a nice piece, but you don't need it. Just hook a piece of hose off of the manifold directly to the map sensor. That's how the older Hondas did it. I did that with my JRSC and ran as high as 12 psi with no probs.
Sonny
Old Dec 15, 2004 | 08:36 PM
JRciv's Avatar
Default Re: Switching to Uber - JRSC MAP question (Sonny)
But how do I hook up a vacuum hose to the MAP sensor? I'd need some sort of adaptor.
I think I'll just keep the JR piece and sell the MAP controller without it.
Old Dec 15, 2004 | 10:08 PM
Sonny's Avatar
You don't need an adapter. The map sensor itself has a nipple on the end. Plug that into a piece of hose. Plug the hose into a nipple on the manifold.
Sonny
SINISTR
Feb 20, 2008 09:38 AM
hondaeg8
Jul 29, 2005 07:41 PM
93supercoupe
Feb 10, 2005 02:29 PM
jbs
Feb 19, 2004 07:54 AM
deez92
Aug 8, 2003 07:37 AM
