removing dash
Old Nov 12, 2017 | 11:00 AM
jdmark1's Avatar
Default removing dash
I'm going to pull the dash to change out my heater core, but I'm sure I'll run into a lot of plastic clips/retainers. Is there a special tool to take them out more easily?
Old Nov 13, 2017 | 10:06 AM
thewrai6th's Avatar
Default Re: removing dash
Removing the dash is one of the most difficult things I have ever done on a Honda. It's not an easy task, but I don't think you need any special tools. The main PITA for me was disconnecting all the various wiring harnesses. There are some DIY articles out there, so I suggest you follow them.
Official Dash Removal How-To *pics* - Team Integra Forums - Team Integra
Old Nov 15, 2017 | 10:23 AM
jdmark1's Avatar
Thanks for the link. And I actually did find a tool for the plastic retainers. You use it instead of a small flat head to pull the clips out easier/without breaking them.
Old Nov 15, 2017 | 12:14 PM
MotorMouth93's Avatar
10 Year Member
I'd just replace the clips with new ones. The old ones are 15+ years old at this point and get brittle, loosen, etc. over time. You'll end up with less rattles just replacing them.
Old Nov 15, 2017 | 12:25 PM
thewrai6th's Avatar
^ This. I replaced almost every damaged clip/ziptie. I didn't want the wires rattling. For the clips I could get out, I used needle nose pliers.
Good luck!
rick1574
12
Aug 22, 2010 09:21 AM
prolifik22
Nov 10, 2007 01:51 AM
evsproject94
Apr 2, 2004 07:11 AM
neilff
Apr 24, 2003 09:46 PM
