1990 Integra b18 crank but no start
Old 02-17-2018, 01:50 AM
Joe Sauls's Avatar
Default 1990 Integra b18 crank but no start
I have a 1990 b18 integra rs sedan that was running perfectly fine and then just died. Will not fire back up again. Have checked every ground, solid. Have checked every injector for power and flow, and checked the fuel pump and filter for clogs, power and flow, all good there. Distributor gets power, rotor and icm function properly. When the cap is off, the rotor spins and the ignitor fires solid, but when i put the brand new cap on it doesn't send power to the leads so the brand new wires and brand new plugs (properly gapped) arnt getting spark. I have checked the main relay and all solder points look okay and the relay clicks when key turned to on position, as well as no arcing of any solder points. Also looked at the ecu for any flashing lights and nothing, no check engine light, I even removed the ecu fuse for 10 minutes to reset it and no progress. I literally have no idea what to check next. Any help would be greatly appreciated.
Last edited by Joe Sauls; 02-17-2018 at 01:55 AM. Reason: Added more things I've checked
james myers
Engine Management and Tuning
01-19-2017 12:08 PM
nyckid
04-10-2015 08:38 PM
Nikpan
08-18-2013 03:50 PM
tweekdb17
15
02-03-2010 07:20 AM
Quick Reply: 1990 Integra b18 crank but no start
