Temperature Sensor Not Working
Old Dec 4, 2017 | 09:12 PM
test_subject_15's Avatar
Default Temperature Sensor Not Working
hi. I have a 96 Integra gsr and the temp sensor takes a long time to get to half if at all. Sometimes it just stays near c for the whole drive and I'm thinking that's gotta be wrong right? Any insight on what to do about this? Thanks guys!
Old Dec 4, 2017 | 09:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Temperature Sensor Not Working
Your thermostat could be stuck open... it may not be the sensor. Try starting the car cold and letting it sit and warm up at idle... if the temp gauge sweeps smoothly from cold to normal operating temperature, then the sensor is likely just fine.
Old Dec 6, 2017 | 09:15 PM
yeah sometimes it seems like it's working fine but others it just stays at C even tho I just drove for st least 15 min.
Old Dec 6, 2017 | 09:34 PM
MotorMouth93's Avatar
10 Year Member
Plug an OBD reader in and see what temp the ECU is reading, it has a separate sensor from the one in the gauge cluster. If the ECU is seeing hot coolant and the gauge says cold coolant then you have a sensor issue, if they both read hot the same then it's a thermostat issue.
Old Dec 7, 2017 | 12:46 PM
thewrai6th's Avatar
If it's really taking that long to warm up, you either have a stuck thermostat or someone took it out completely.
davidluko
Nov 19, 2006 08:27 AM
Pablo Escobar
May 15, 2006 07:49 PM
john457
Dec 21, 2005 08:59 PM
99-DC2
Apr 28, 2004 08:39 PM
