Bad fuel pump on my 94 gsr?
So my 94 gsr coupe died on me a couple weeks back when I was doing a U-turn in couldasack. It took me about 4 times to get it to start. And sometimes when I slightly accel in low rpms in 1st gear it feels like I'm losing power. (A day before this my cel came on)Also right after I fill my car up with gas, my car jerks a bit when I drive it. So yesterday I went some place with my car, I drove there with no problems but still had the feeling of losing power. When I was about to leave, my car started up fine then it just casually died out probably 10 seconds after starting it. I started to crank it a couple times and I get nothing but cranks. I hear the main relay click but I hear no fuel pump priming. I swapped out the old relay with another one and I get the same results. I didn't check fuel pressure yet so would anybody know what would be wrong? I'm trying to get my daily up and running again.
Re: Bad fuel pump on my 94 gsr?
could easily be the pump they dont last forever.
i always carry a spare. swap it out with a rockauto
cheapy if you dont have 100 clams for a denso.
you'll need one sooner or later anyways.
Also I just found out that my 15a ecu fuse is blown, and my fuel pump relay clicks so I didn't bother checking for fuel pressure. So I just went ahead and bought a fuel pump online.
Last edited by Joshbreeezy; 09-24-2017 at 04:51 PM. Reason: Forgot to add something
Jooleeus
12-22-2009 06:47 PM
