Map sensor issues
Old Mar 18, 2018 | 06:38 PM
blowme510's Avatar
Icon5 Map sensor issues
hi there I have bin dealing with a map sensor issue and I have bin trying to figure it out. I have tried multiple known good engin harnesses multiple known good map sensors and it’s always stuck at 9.4 psi and it causes the car to stay over fueled at all times
and the car info is a 1995 Acura integra ls with a b20v n/a any help would be much appreciated
Old Mar 19, 2018 | 03:59 PM
CloudStrife's Avatar
Default Re: Map sensor issues
9.4 PSI for what? Fuel pressure?
Old Mar 19, 2018 | 08:09 PM
blowme510's Avatar
At the map sensore even if it is unpluged or pluged. An i am getting the reading on a known good hondata s300
Old Mar 20, 2018 | 08:11 AM
jdmark1's Avatar
Do you have a vacuum leak anywhere? I would think that would cause your MAP to read wrong. Also, try getting a reading from it with the engine off. It should be around 14.7 psi as that's atmospheric pressure. If it isn't then I would think you have an issue with the ECU because you've tried multiple known good sensors and harnesses.
Old Mar 21, 2018 | 12:21 PM
blowme510's Avatar
Its on a known good hondata s300 and it reads that at all times pluged or unpluged
Old Mar 21, 2018 | 02:38 PM
jdmark1's Avatar
What BAR map sensor are you using? Don't you have to mess with settings and calibrate it correctly depending on the MAP sensor you're using? I'd try asking over on the hondata forums
Old Mar 21, 2018 | 05:23 PM
blowme510's Avatar
It is a stock map sensore with stock ls base map
spockeg
Engine Management and Tuning
22
Oct 19, 2009 07:54 PM
insaneconceptz
Mar 7, 2009 01:08 PM
boostedcivicsir
Oct 26, 2008 02:14 PM
lovey408
Jun 18, 2007 04:34 PM
HiGhCaM
May 11, 2002 11:40 PM
