piston replacement
Old Oct 14, 2017 | 08:31 PM
athan's Avatar
Default piston replacement
suggested mileage for piston replacement?
Old Oct 15, 2017 | 08:14 AM
qfast817's Avatar
Default Re: piston replacement
Normally if it's not broke don't fix it.
It depends on oil blow by do you see blue or white smoke on start up? Are your plugs caked with oil?
You can do a compression test and see if you have low compression. If you do then do a leak down and see if your valves/rings/head gasket is leaking.
Old Oct 27, 2017 | 08:06 AM
Doodasi's Avatar
when they are worn beyond factory replacement specifications. Are they out of the engine?
rick_rabies
Sep 15, 2009 03:30 PM
andystart
14
Oct 15, 2004 08:52 AM
ILLA_00LS
Jul 22, 2003 12:06 PM
F1Spec
Nov 8, 2002 05:57 PM
