B20 integra cabin heating & engine cooling issues
1994 b20z integra was having a hot start symptom that once car was up to temp it would stall and not start until cool again. Spark is still present on stalls an if i did try and crank it would smell like raw unburnt fuel so i bought a new ECT sensor that i replaced this evening. My problem now is that heat isnt getting hot which was hot 2 days ago and have some intermittent bubbles even tho car has cycled several times. I turned car off to see if hot start was still an issue and nearly all coolant gussed out from radiator when cranking. Not smoke from exhaust and no sighns of coolant in the oil
