Integra LS
Old Sep 17, 2017 | 07:15 AM
anthony138's Avatar
Default Integra LS
Hows it going guys i have a 97 tegg ls. Stock besides headstuds and oil pan and motor mounts. Im getting a misfire code. For all 4 cylinders but not loosing power. Then all of a sudden i was driving. And she shut off on me. Im thinking crank position sensor but im not getting that coxe any ideas?
Old Sep 17, 2017 | 05:41 PM
Scorchin Civic's Avatar
Default Re: Integra LS
Might be a shot in the dark but is it getting spark? A common problem with the Integra is the coil inside the distributor going bad.
Old Sep 18, 2017 | 10:00 AM
anthony138's Avatar
She is getting spark. I changed the distributor with an extra i had. Sounded alot better till i blew the distributor. So i just ordered a new one and ill change that and see if that helps any And fixes the cel. As far as the stalling i think it may be the throttle cable being too loose. Im not sure but i can tell the kid before me, made up for the engine mounts being shot by adjusting the cable. So it may have stretched?? Causing alittle slack just enough to completly close the throttle body?
Old Sep 28, 2017 | 10:23 PM
anthony138's Avatar
Code went away. And didnt come back it was really weird!
Old Sep 29, 2017 | 01:47 AM
NVturbo's Avatar
O.G. triple O.G.
if you have interment codes pop up, something is going out, wire is bad, or a connector plug is not making good connection.
Car Tweaker
May 14, 2009 05:32 AM
ExclusiveCRX
Mar 12, 2007 09:23 AM
tegasaurus
Aug 18, 2004 12:39 AM
crxwagon
Jul 13, 2004 08:34 AM
type Gendy
17
Nov 28, 2003 07:35 PM
